Main : Misc : Tech Section H165 + SSL
[<   Previous  411  412  413  414  415  416  417  Next   >]
H165 + SSL
H165 + SSLPopular
Submitter1200coupeMore Photos from 1200coupe   Last Update2005/8/10 7:16    Tell a friendTell a friend
Hits3952  Comments13    0.00 (0 votes)0.00 (0 votes)
Spring loaded locker
cheater_5
Posted: 2005/8/14 5:56  Updated: 2005/8/14 5:56
 Re: H165 + SSL
Cheers A14force
Helped a lot. It all looked like nothing to me but it makes ense now
Looks like real nice work too.
cheater_5
Posted: 2005/8/11 10:18  Updated: 2005/8/11 10:18
 Re: H165 + SSL
I know this is prob a stupid question but the only way to learn id to ask so....
i know thts a diff but wats bin done to it and wat does it do??
cheers
A14force
Posted: 2005/8/12 22:30  Updated: 2005/8/12 22:30
 Re: H165 + SSL
OK, see the blocks of steel in the centre part of the diff? They are hard steel plates, which are held against the side gear faces with strong springs. The hole through the middle where the shaft goes which the idler gears are running on, is more like a slot than a hole. When the diff is put under load, the side gears rotational motion, tries to twist the plates. This forces the slot in the plates to try and climb away from the pin, thus jamming the plates against the side gear faces, preveting the axles from turning independently, and giving two wheel drive.
Thats the idea anyway.
1200coupe
Posted: 2005/8/10 7:19  Updated: 2005/8/10 7:19
 Re: H165 + SLL
I had my diff out of the rally car the other day and took this pic so other members could see what a Spring Loaded Locker looks like when fitted to a H165 centre.
No signs of appreciable wear after many events - so its all good.
Posted this one for you A14 force
A14force
Posted: 2005/8/10 10:46  Updated: 2005/8/10 10:46
 Re: H165 + SSL
OOOOH shiney!
I wish I had one. WAIT, I do!
It's a pity I don't have a better camera than the one in my POS phone. (never buy a hyundi)
I wont get to test mine out untill my new engine goes back together. whenever that is..........:)
dattoman_1000
Posted: 2005/8/10 12:24  Updated: 2005/8/10 12:24
 Re: H165 + SSL
Where and how much ?
Do they fit any centre ?
I think mine is a H145 but not sure
benny
Posted: 2005/8/11 0:57  Updated: 2005/8/11 0:57
 Re: H165 + SSL
From memory im pretty sure that "1200coupe" made his from scratch.......
Benny
1200coupe
Posted: 2005/8/11 1:10  Updated: 2005/8/11 1:10
 Re: H165 + SSL
Yep I designed and made this one to fit my diff centre. Do a web search under "phantom grip" lots of info there and maybe links to manufacturers.
No, each centre will require a similar design but will be dimensionally different.
1200coupe
Posted: 2005/8/11 7:11  Updated: 2005/8/11 7:11
 Re: H165 + SSL
Bart - notice the location of the Aluminium Bronze thrust washers we were talking about. There is no wear at all on the sides of the locking plates so they are doing a fine job stopping excessive end float and damage to the spider gears.
You slack azz, get a camera and email me pics of what you came up with
Quinn
Posted: 2005/8/13 0:32  Updated: 2005/8/13 0:32
 Re: H165 + SSL
hey a14force where did you get your one from? ive checked out the phantom grip website and there is no listing for Datsun/Nissan H165 diff. At $300us they sound like a bloody good deal.
who_your_datty_1200
Posted: 2005/8/13 0:39  Updated: 2005/8/13 0:39
 Re: H165 + SSL
Quinn......... He build it himself. Next time I am at Front bum's (Barts)place, I will take a photo and thats only if he gets it out of the car!!! Which by the way still has no motor!! Come on Bart you slack front bum get off your ass and build that motor. I know you want too!!
Quinn
Posted: 2005/8/13 0:53  Updated: 2005/8/13 0:53
 Re: H165 + SSL
sorry I thought he might have modified an existing one to fit. If you could share the design it would be a huge help as Ive got a 4age going infront of my H165 and it would be nice to get both wheels smoking!
A14force
Posted: 2005/8/13 23:03  Updated: 2005/8/13 23:03
 Re: H165 + SSL
!200 coupe and I should write something for the tech section.
When I get a moment, I'll compile all the stuff that Paul sent me.
