Main : Mechanical : Fuel Injection New Injection
[<   Previous  177  178  179  180  181  182  183  Next   >]
New Injection
New InjectionPopular
Submitterrally1200More Photos from rally1200   Last Update2005/8/14 14:20    Tell a friendTell a friend
Hits3414  Comments11    0.00 (0 votes)0.00 (0 votes)
This is the new injection setup.
sidedraught
Posted: 2005/8/14 14:43  Updated: 2005/8/14 14:43
 Re: New Injection
This looks like a serious setup.
Excellant work, that old strut tower really cuts into your engine bay in the 1200.
D
Posted: 2005/8/15 4:46  Updated: 2005/8/15 4:46
From: under the Firmament LOL no twiglight effect BS
 Re: New Injection
Just need datto 1000 front suspension
Great job on these, what size are they 36mm ?
dattodevil
Posted: 2005/8/15 9:57  Updated: 2005/8/15 9:57
 Re: New Injection
Very cool, did you make those bosses up?
converted
Posted: 2005/8/15 10:13  Updated: 2005/8/15 10:13
 Re: New Injection
v nice...Im almost envious...apart from the fact I have a set of 50mm throttle bodies to chuck on my engine!!!
I would love to know how much difference it would make on the dyno...
D
Posted: 2005/8/15 12:16  Updated: 2005/8/15 12:16
 Re: New Injection
Converted 50mm are ridiculously too large for anything under 2.1ltrs. Honda s2000 run aournd 45mm to make 240hp.
48s are perfect for racing stroker l20b 2.4ltrs and ka24e racing motors and perfect for 26b (2x13b) racing mazda rotaries.
rally1200
Posted: 2005/8/15 12:30  Updated: 2005/8/15 12:30
 Re: New Injection
They are 43-44mm from a toyota 4AGE 20 valve. The throttle body and trumpet is the same length as webber without a trumpet so there is plenty of room for a pipercross airfilter and should give good power at 7000-8500.
converted
Posted: 2005/8/15 14:29  Updated: 2005/8/15 14:29
 Re: New Injection
D , I would also have agreed as would many and choke them to 44-45mm using alloy 50mm tubing with 4mm sidewalls...however, Jeff Taylor said to try them at the full 50mm so thats what i'll do. He has never led me astray and me thinks he is not starting now. I will also be tuning for avgas so it will interesting to see the power gain (if at all)...
Now his theory is with webers it relys on air pressure over the venturi to suck the fuel out and then atomise it ready for ignition, but with fuel injection, it is already pressurised at 45psi and the injector fires at the prescise moment. This allows more aire fuel mix and therefor more bang.
bring on the myth busters....
rally1200
Posted: 2005/8/15 14:43  Updated: 2005/8/15 14:43
 Re: New Injection
Here is a side pic showing the room for the airfilter.
Side Pic Link
Clubman
Posted: 2005/8/16 0:47  Updated: 2005/8/16 0:47
 Re: New Injection
Nice conversion. I am about to do the same conversion to my A15. How did you get the throttle bodies so clean?
D
Posted: 2005/8/16 8:23  Updated: 2005/8/16 8:23
 Re: New Injection
Converted it will be interesting to see if they get enough air velocity to help air/fuel mix.
Anyone here know who made the spacer plates?
Also anyone know who can make custom alloy inlet manifolds?
Lemonhead
Posted: 2005/8/16 9:15  Updated: 2005/8/16 9:15
 Re: New Injection
rally1200, Are they an of the shelf ramtube or did you make them, I in the market for new ones, I'm looking for parallel tube ones with the at least a half round profile on the inlet side.
Thanks Gary
P.S are you "involved" with this years Glouster Park stages with this years WRC
rally1200
Posted: 2005/8/16 16:35  Updated: 2005/8/16 16:35
 Re: New Injection
The ramstube was from my local speed shop he gets them spun and has a good range. I had the base plate machined up to fit the 4AGE setup.
They haved change the format this year. They are going to have legends of the ARC, past winners. but the organizers have asked if Murray Coot could use my car so i will be co-driving instead.
