Main : Mechanical : Fuel Injection Latest Engine Pic
[<   Previous  174  175  176  177  178  179  180  Next   >]
Latest Engine Pic
Latest Engine PicPopular
Submitterrally1200More Photos from rally1200   Last Update2005/10/2 12:06    Tell a friendTell a friend
Hits4100  Comments7    0.00 (0 votes)0.00 (0 votes)
This is the latest update to my fuel injection
Dodgeman
Posted: 2005/10/2 12:47  Updated: 2005/10/2 12:47
 Re: Latest Engine Pic
VERY impressive.
Do you run any form of air filtration, or is that it?
It must sound awesome at full song & i'm guessing that there's an electric water pump just out of the picture somewhere.
rally1200
Posted: 2005/10/2 12:56  Updated: 2005/10/2 12:56
Yes the large aluminium backplate is for a pipercross filter, trumpets fit inside just nicley. and yes i have another pic of the engine without head showing the ARP stud kit but in that photo you can see the davies craig water pump.
rally1200
Posted: 2005/10/20 14:38  Updated: 2005/10/20 14:38
OK dyno result back, this setup gets only 1 hp more at top end compared with my old TPS setup. up to 105hp(wheels) corrected power at 7600rpm but between 3500-5500rpm it has lost 20% torque and 10% hp. me thinks that it is just to big (43mm). So i am after some webber chokes 32/34/36mm to try and get some power back if you have some to sell please let me know.
blofly
Posted: 2005/10/20 15:48  Updated: 2005/10/20 15:48
cool pic! I can't believe you will take it on dirt and get it all dirty, it's just too pretty for that man!
1200coupe
Posted: 2005/10/21 3:49  Updated: 2005/10/21 3:49
I will be very interested to see if you can get your midrange torque back to the same figures as the old TPI set up. I dont think you will but would like to be proved wrong.
I have seen this tried once before on a Z motor with single TB set up, once changed to multi TB's with the right choke size and many dollars spent, he lost 14% midrange and only had a 4 Kw increase at peak power.
Good luck with the developments and keep us posted. I like the quality of your work.
tsillay
Posted: 2005/10/21 4:22  Updated: 2005/10/21 4:22
43mm is pretty big, that's about what the fj24 used to run on carbs...
im currently running 50mm holes on a 2100 twincam, andthey're too big..
rally1200
Posted: 2005/10/2 12:20  Updated: 2005/10/2 12:20
This photo was taken after the last state rally in W.A. Stirling Stages where we (me and the 1200 coupe) have taken out the PRC1 championship beeting Suzuki Swift GTI's, Daihatsu Charade's and Toyota Corolla's. Go the Datto..
Freak
Posted: 2005/10/2 12:41  Updated: 2005/10/2 12:41
Looks great. The trumpets look trick.
Just curious. Everytime you set the tappets do you have to take off the strut brace?
