Main : Misc : Forum gemini radiator in 120 y turbo
[<   Previous  457  458  459  460  461  462  463  Next   >]
gemini radiator in 120 y turboPopular
Submitter120flyMore Photos from 120fly   Last Update2005/8/16 12:26    Tell a friendTell a friend
Hits2701  Comments3    0.00 (0 votes)0.00 (0 votes)
I fitted the radiator today and rebuilt my heater unit will be connecting it all tommorrow
muppet
Posted: 2005/8/17 5:47  Updated: 2005/8/17 5:47
Quite a regular
 Re: gemini radiator in 120 y turbo
How easy was it to fit any modifing need, what Gemini was it from?
120fly
Posted: 2005/8/17 11:09  Updated: 2005/8/17 11:09
it was quit easy to fit i used the standard mounts on the radiator .I only had to cut the raditor front panel bigger for the air not to shore if the thermo is standard or what gemini it came from, it came with the turbo set up maybe harry will be able to tell us what gemini it came from.I put an extra breather to run to my oil catch can
SORRY for being slack in reply ive been in the garage working on my datto
matsfatdat
Posted: 2005/8/18 12:06  Updated: 2005/8/18 12:06
What model gemy was it from?
Freak
Posted: 2005/8/18 12:50  Updated: 2005/8/18 12:50
Im pretty sure all the RWD models had the same radiator. When I went to the wreckers thats all I asked for. Unless it was a fluke it was from the right model. The only reason we use gemini raditors as the inlet/outlet are in the correct position for the Aseries.
evilsim
Posted: 2005/8/16 16:51  Updated: 2005/8/16 16:51
is that the stock electronic fan over your gemmy radiator ? im using an aftermarket one but have been looking for a slim alternative to use as a pulling fan rather than my setup with it pushing.. (pushing is meant to be less efficient, also it blocks good radiator space on the front)
also, whats with the rocker cover oil escape being near the front of the motor !?
