Main : Mechanical : Engine GB120 Engine bay A15R
[<   Previous  2492  2493  2494  2495  2496  2497  2498  Next   >]
GB120 Engine bay A15RPopular
SubmitterdattodevilMore Photos from dattodevil   Last Update2005/9/3 8:32    Tell a friendTell a friend
Hits3735  Comments4    0.00 (0 votes)0.00 (0 votes)
The rebuilt engine with the new PCV system hooked up, using SR18DE PCV valve hooked into a custom balance tube
dattodevil
Posted: 2005/9/3 11:11  Updated: 2005/9/3 11:11
 Re: GB120 Engine bay A15R
Slowly getting everything done, would like to get a reduction starter next. Apparently there may be a straight bolt up replacement. Also would love to get the fittings etc all replated, just to add that finishing touch.
datrat_dave
Posted: 2005/9/3 14:59  Updated: 2005/9/3 14:59
GB120? and A15R? Whats these stand for, the A15 racer?
Very nice dude has come together quite shibbily,the alternator bracket kinda needs the same blue im thinking...
Dave
A14force
Posted: 2005/9/3 23:04  Updated: 2005/9/3 23:04
I've been giving your Idea some thought Damon. Have you considered that having a balance tube set up in place, may reduce idle quality, By allowing Exhuast gas plulses to corrupt the vacuum signal to other cylinders?
Just a thought.
dattodevil
Posted: 2005/9/3 23:24  Updated: 2005/9/3 23:24
You might be right there Bart, but it's still manifold vacuum, so in theory it should lessen the effect. It seems to run quite smooth.
And yes Dave the R is for racey
