Main : Members : Wogboy intercooler pipe work
[<   Previous  25  26  27  28  29  30  31  Next   >]
intercooler pipe workPopular
SubmitterWogboyMore Photos from Wogboy   Last Update2005/12/28 19:16    Tell a friendTell a friend
Hits2600  Comments8    0.00 (0 votes)0.00 (0 votes)
this is the pipe that goes from the intercooler to the plenum
Wogboy
Posted: 2005/11/16 7:24  Updated: 2005/11/16 7:24
 Re: intercooler pipe work
I had to fabricate the bend as it is too tight to get a mandrell bend in
1200rallycar
Posted: 2005/11/16 7:27  Updated: 2005/11/16 7:27
holy crap!!!
you cut all those sections up and welded together to get the tight bend?
10/10 for effort!!!
Wogboy
Posted: 2005/11/16 7:31  Updated: 2005/11/16 7:31
thanks 1200rallycar, but it's just one of those things you just got to do I'm pertty happy with the result as it looks quite neat (just like a bought one )
L18_B110
Posted: 2005/11/17 4:43  Updated: 2005/11/17 4:43
you have far more patience than me!
not to mention welding ability...
blofly
Posted: 2005/11/17 5:01  Updated: 2005/11/17 5:01
that is very immpressive! I have never been good at working with angled pipe work. I am a refrigeration/air conditioning mechanic by trade so that should be a big concern!!!! no problem with pipe benders though has anybody seen the flexible steel ducting? it is made from mild steel and is a corrugated duct-like product. good for using where there is alot of heat, used to use it next to hot water pipes and gas burner extraction systems for air vents. it was fully flexible and quite strong. maybe it could be used in areas like that??
phunkdoktaspok
Posted: 2005/11/17 7:51  Updated: 2005/11/17 7:51
Lots of Japanese mags show that this style of pipework is very fashionable. I think they call it Lobsterback pipework.
Wogboy
Posted: 2005/11/17 22:43  Updated: 2005/11/17 22:43
phunkdoktaspok that is correct it is called a lobsterback
blofly quite easy to achieve it just takes a bit of time and patients you just draw 2 radius one for the I.D and one for the O.D and then the width of each piece so that you can see it on paper work out the angle of the cut and away you go (it goes into a lot mor detail than how I just explained but this is the easyer way to explain it )
Michael
Wogboy
Posted: 2005/11/17 22:47  Updated: 2005/11/17 22:47
blofly I forgot to mention that flexy stuff you mentioned it probably would leak at a guess because under boost 25psi but than again I might be wrong as I've never seen the stuff and I dont know how it is held together
Michael
