Main : Members : Wogboy lowered
[<   Previous  14  15  16  17  18  19  20  Next   >]
lowered
loweredPopular
SubmitterWogboyMore Photos from Wogboy   Last Update2005/12/28 19:22    Tell a friendTell a friend
Hits2949  Comments14    0.00 (0 votes)0.00 (0 votes)
still trying to get the right ride height
Wogboy
Posted: 2006/7/31 13:18  Updated: 2006/7/31 13:18
 Re: lowered
clammy I got everything done in one go so I dont know how much each front guard is worth as they were reshaped quite a bit from the standard shape
matty
Posted: 2006/7/31 14:29  Updated: 2006/7/31 14:29
 Re: lowered
Clammy - I paid $250 from memory for the front of the guards to be trimmed, the inner lips rolled and hand pumped and then resprayed.
clammy
Posted: 2006/6/1 7:07  Updated: 2006/6/1 7:07
 Re: lowered
hope you got the front of your front guards cut out a bit, i am having the problem now that because the wheels are big, they hit the guard when you turn.... if you have had this done, could you PM me with around about how much you paid for it?
cheers
cam
Wogboy
Posted: 2005/12/21 10:57  Updated: 2005/12/21 10:57
 Re: lowered
thats classified information there Normo
Wogboy
Posted: 2005/12/21 10:21  Updated: 2005/12/21 10:21
 Re: lowered
I think you might have hit the nail on it's head there never even thought of that will give it a go once I put the fuel tank in and all of the other stuff just to make sure
Thanks for the sugestion
Michael
normo
Posted: 2005/12/21 10:38  Updated: 2005/12/21 10:38
 Re: lowered
so looking at the excellent ballast in the rear (battery and fuel girl)
do you get a charge out of her
how many smiles to your gallon?
I am having a ride height problem as well
15" all round but I need low profiles but with the coilovers I need 185/45/15 orthereabouts, but no wider.
Wogboy
Posted: 2005/11/18 11:10  Updated: 2005/11/18 11:10
 Re: lowered
trying to get the correct ride height, I think the front is about right but I think I need to raise the rear by about 10mm(thats my better half in the rear to compensate a tank of fuel and battery, as there not in yet)
datto1200ute_qld
Posted: 2005/11/18 11:58  Updated: 2005/11/18 11:58
 Re: lowered
hard to tell by that pic...................but can it ever really be to low?
Wogboy
Posted: 2005/11/18 15:04  Updated: 2005/11/18 15:04
 Re: lowered
the measurement from the ground to the wheel arch is 595mm front and rear
works1200
Posted: 2005/11/18 21:58  Updated: 2005/11/18 21:58
 Re: lowered
i think it needs some 14x7 watanabes on it.. :) and i'm almost positive we have the same intercooler. hehe.. nice ute!
muke
Posted: 2005/11/18 23:16  Updated: 2005/11/18 23:16
 Re: lowered
mm Tuff ute man.
where'd u score the rims and how hard were thei to fit...
-muke
Wogboy
Posted: 2005/11/18 23:59  Updated: 2005/11/18 23:59
 Re: lowered
muke I've got s13 silvia front coil overs and the just clear them and in the rear is a r31 skyline diff shortened I dont know the name of the wheel but there a Lenso copie 17 X 7's and I got them from Meng tyers in Mackay (locally owned ) but all good tyre shops should have them.
matbighat
Posted: 2005/11/20 5:19  Updated: 2005/11/20 5:19
 Re: lowered
That's the problem with 17's you can't lower that much ...
Wogboy
Posted: 2005/11/20 8:45  Updated: 2005/11/20 8:45
 Re: lowered
yea the 17's make it look lower just because the gap between the tyre and the guard as for lowering it, it only has 30mm lowering blocks in the back and I also took the helper leaf out of the rear cut it 70mm either side of the locater bolt and then reinstalled it on top of the leafs, and I dont know how much the front is lowered as I have coilovers in
Michael
Cable_Tie
Posted: 2005/12/21 0:39  Updated: 2005/12/21 0:39
 Re: lowered
Does the helper spring flatten the spring out at all? Maybe removing it will give you the 10mm you are after?
