Main : Members : B120dat My WEBER 32/36 (finally)
[<   Previous  102  103  104  105  106  107  108  Next   >]
My WEBER 32/36 (finally)Popular
SubmitterB120datMore Photos from B120dat   Last Update2003/1/23 8:02    Tell a friendTell a friend
Hits12450  Comments14    0.00 (0 votes)0.00 (0 votes)
just got it on. it goes hard.
i had to advance the dizzy ohhhhhh that wasnt fun :P
B120dat
Posted: 2003/1/23 8:17  Updated: 2003/1/23 8:17
 Re: My WEBER 32/36 (finally)
whats the matter with it on the fire wall?
1200rallycar
Posted: 2003/1/23 8:18  Updated: 2003/1/23 8:18
nothing, just never seen it
actually i was thinking its a good place to keep it away from splashes of water, for on the rally car, though its usually the dizzy that the prob with water
B120dat
Posted: 2003/1/23 8:21  Updated: 2003/1/23 8:21
thats where my origanal coil was form when i got it. i am sure it has been since factory because there are no other brackets for it in the engine bay
benny
Posted: 2003/1/23 23:47  Updated: 2003/1/23 23:47
on some models, this is where the coil is from factory.
Looks great b120dat, just a tip if you havent already done it, is to file away the bridge on the inlet manifold, where the primary and secondary throats from the old hitachi carb mounted up to, underneath the weber adaptor, so that there is one large hole that matches the size of the weber adaptor, this significantly improves the flow.
Cheers
B120dat
Posted: 2003/1/24 2:23  Updated: 2003/1/24 2:23
yeah i read that some where i think it is call the "plaeum" area or sometihng like that
do i need special tools to do that? because it neeeds to be smooth to allow nice flow
(yeah benny how did you go on the carbs?)
benny
Posted: 2003/1/24 3:31  Updated: 2003/1/24 3:31
When i had a downdraught setup, all i used to modify the manifold was a hacksaw blade and a file. worked fine.
(when i called the guy about the carbs there was no answer)
Cheers
Posted: 2003/1/24 7:18  Updated: 2003/1/24 7:18
For those not familiar with the idea, if it's a thick adapter, use a large round rasp to make quick work of it, then fine it up with a file.
What kind of coil is that? All the 1200s here have traditional round coils.
B120dat
Posted: 2003/1/24 10:41  Updated: 2003/1/24 10:41
its a "GT40RT" coil its a high perfromance it just creates a better surge for you to get a better spark, it says on packet: starts the car better quicker, higher spark, larger surge etc
i bought coil, top gun leads, new dizzy cap, new rotor and i changed my spark plugs
jaimecidpedro
Posted: 2003/1/24 21:37  Updated: 2003/1/24 21:37
A better coil makes a lot of difference. I got a accel , the big yllow coil, the name is, super coil by accel, and it starts faster, stronger, has better spark at all speeds.I also have a 32/36 in my A15. I also noticed that area to be grinded, I will do it upon taking the head out for some valve and port work. I noticed, though, that if I am to make the manifold as big as the adaptor's opening,then, there is going to be very little manifold wall left. How far can I go, how much is too much, I think that the change in response will be noticeable, there is , right now a part of the stock manifold that hinders flow.
1200rallycar
Posted: 2003/1/25 1:10  Updated: 2003/1/25 1:10
B210sleeper
Posted: 2004/7/19 18:40  Updated: 2004/7/19 18:40
What jets and emulsion tubes are best for an A15?
B120dat
Posted: 2003/1/23 8:12  Updated: 2003/1/23 8:12
i would like a sidedeaught some where down the road, but at the moment the 32/36 is doing a goood job
some wheeeellll spin
1200rallycar
Posted: 2003/1/23 8:15  Updated: 2003/1/23 8:15
what with the coil on the firewall?
thats one clean carby!
