Main : Misc blue 1200
[<   Previous  4725  4726  4727  4728  4729  4730  4731  Next   >]
blue 1200
blue 1200Popular
Submitterbrocky41More Photos from brocky41   Last Update2006/3/5 8:00    Tell a friendTell a friend
Hits2840  Comments7    0.00 (0 votes)0.00 (0 votes)
ame with twin delortoes but wernt working properly 2 cylinder at idle the 4 wen u revvd it over 5000rpm went to a15 carb
brocky41
Posted: 2007/1/17 10:20  Updated: 2007/1/17 10:20
 Re: blue 1200
the guy whom has just put these back on for me said the the engine was pretty tired and because the poor little motor is trying to suck the air and fuel thru basically 4 times what it used to with stock carb , 1 port per carb with sidies, the engine doesnt have enuff suck at idle to get it thru the carbs, also they are a little over fueled for a12 and wouldgo mint on a15, the engine still has good compression still but obviously not enuf vacum you can also try changing emulsifying tubes etc in the carbs
Posted: 2017/1/14 20:47  Updated: 2017/1/14 20:53
 Re: blue 1200
That's what I used to think too, twin carbs must flow twice the air. But then I read the Weber Handbook and found out the without the plenum, they flow nearly the same as a single carburetor (something about 4-cycle engine only having an induction stroke once per two revolutions = 1/rpm with a 4-cylinder).
Also all engines suck the same at idle, around 18-22 inches (unless they are worn out), V8, 6 or 4
Dual Dellorto DHLA40 are too small for A12 when fitted with the smallest venturis (basic tuning parts). But just right for an A12 if fitted with the 27mm ones. And just right for A15 when tuned with 31mm venturis. Nissan New Zealand used 28mm venturis on their round-port A12 with high-RPM camshaft. See Dellorto Tuning for Datsun 1200
Posted: 2017/1/14 21:42  Updated: 2017/1/14 21:47
 Re: blue 1200
Cylinders 2&3 arnt going at low revs
check your idle circuits (I dont know what that means but thats what people told me when mine was doing it)
does anybody know what or where the idel circuts are or how to fix them?
This is an old question but a common one. The answer may help someone searching ... the Idle circuit is the fuel passages and adjustment valves that allows the engine to idle. It only works at low RPM generally below 1500 RPM
* with single carb, anytime an engine won't idle below 1500 RPM, but will run steady at 2000 RPM or higher, check the idle circuit
* with dual carb, anytime an engine runs on 3 or 2 cylinders below 1500 RPM, but will on all 4 at 2000 RPM or higher, check the idle circuit(s)
Dellorto DHLA idle mixture screws
1. Start engine, let it warm up fully, and let it idle
2. Go to one of the Idle Mixture screws. Count the number of 1/2 turns it takes to screw it in. Use a light touch and don't force the screw tight
* As you screw it in (anti-clockwise) the engine should slow down or even die. That's normal. Back the screw off to the original position
* If the engine does not slow down, even when the screw is all the way in, the idle circuit is is blocked (no fuel is flowing through that side). Congratulations, you've found the problem
3. Repeat for each side of the carburetor
4. Repeat for 2nd carburetor
If you find a 'dead' idle circuit, the carburetor needs cleaning (it doesn't need a kit). Stop the engine, remove the Idle Mixture screw carefully (don't lose the spring parts), then using a can of spray carburetor cleaner, spray straigh down into the passage using the long plastic nozzle of the spray can. Sometimes this is enough to unblock the passage. Replace the screw and start the engine. If the problem still exists, a more thorough cleaning is needed
chris1200t
Posted: 2006/8/24 10:55  Updated: 2006/8/24 10:55
 Re: blue 1200
lol humm does anybody know what or where the idel circuts are or how to fix them?
Cheers
chris1200t
Posted: 2006/8/24 7:24  Updated: 2006/8/24 7:24
 Re: blue 1200
Sorry to bring up an old picture, but i am also getting this same problem, is this a useual problem for twin siddraft carbies?
I am getting spark in all cylinders and the is compression in all cylinders so i think it is my manifold as it was a home jobba but im getting a custom made one done at the moment so hopefully this will eb the answer. Cylinders 2&3 arnt going at low revs but when i giv it a bit like 3000 they kick in.
Are there any other causes for this problem?
Cheers
campo
Posted: 2006/8/24 7:31  Updated: 2006/8/24 7:31
 Re: blue 1200
cheap on fuel
Tyrie
Posted: 2006/8/24 8:47  Updated: 2006/8/24 8:47
 Re: blue 1200
