Main : Members : Ianey Ian's KB10 disc brakes
[<   Previous  20  21  22  23  24  25  26  Next   >]
Ian's KB10 disc brakesPopular
SubmitterIaneyMore Photos from Ianey   Last Update2006/4/8 11:14    Tell a friendTell a friend
Hits2301  Comments7    0.00 (0 votes)0.00 (0 votes)
For Neil and others interested
Ianey
Posted: 2006/4/8 11:23  Updated: 2006/4/8 11:23
 Re: Ian
The callipers are off a JD Camira. Not sure about the discs.
sidedraught
Posted: 2006/4/8 21:34  Updated: 2006/4/8 21:34
 Re: Ian
They look serious, do 13 inch wheels fit over them?
Ianey
Posted: 2006/4/9 0:02  Updated: 2006/4/9 0:02
 Re: Ian
Yep, thats 13's on it now. I will get some better photos when I take the wheel off.
D
Posted: 2006/4/9 2:44  Updated: 2006/4/9 2:44
From: under the Firmament LOL no twiglight effect BS
 Re: Ian
Why the missing bolt?
Topgear
Posted: 2006/4/9 3:26  Updated: 2006/4/9 3:26
 Re: Ian
I run the same Calipers on my 1000, what disc did you use and how did you mount it, what hub did you use?
I used a Telstar vented disc, machined up an Aly front hub to hold it and an Aly caliper bracket that bolted on the front of the stub and utilised all four bolts. The std Camira brake line is JUST long enough when on full lock at full droop...
Ianey
Posted: 2006/4/9 9:08  Updated: 2006/4/9 9:08
 Re: Ian
To be completely honest I dont know much about it. I asked the guy that built it, and he said he ended up trying about 7 different discs before he found one that fitted nicely. Alot of machining has gone into it though.
I dont think that the hole does anything.
phunkdoktaspok
Posted: 2006/4/9 10:34  Updated: 2006/4/9 10:34
 Re: Ian
The hole was used with the original drum brakes and is now not required. Hence why it isn't used
