Main : Members : PIGDOG L series crossmember 3
[<   Previous  164  165  166  167  168  169  170  Next   >]
L series crossmember 3Popular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2006/4/18 9:45    Tell a friendTell a friend
Hits2185  Comments9    0.00 (0 votes)0.00 (0 votes)
passengers side mount
Posted: 2011/6/14 1:59  Updated: 2011/6/14 1:59
 Re: L series crossmember 3
It es a work or art.
D
Posted: 2011/6/14 5:41  Updated: 2011/6/14 5:41
From: under the Firmament LOL no twiglight effect BS
Instead of that step though Id prefer a curve all the way to the start
of the base of the mount. Then you have stress distribution.
Nice setup though.
Anonymous
Posted: 2011/6/11 5:56  Updated: 2011/6/11 5:56
unlikely- he sold the set up last year. i will measure mine for you, should be similar seeing piggy made it too
PIGDOG
Posted: 2011/6/11 7:03  Updated: 2011/6/11 7:03
just sit the engine in the engine bay and make them the height that you want it. you probably dont want them as low as what i made mine. made making the sump a lot of work as the crank its self only had about 15-20mm clearance to the cross member before there was a sump
can sit it a bit higher if you arent going to run a down draft carby and dont mind the higher centre of gravity
D
Posted: 2011/6/11 11:14  Updated: 2011/6/11 11:14
what are engineers like with cutting up crossmembers
Best they dont know or can you pass them...?
Lucky the CA18 sits on a slant and with the FWD exa
sump its a perfect fit. However would be nice to go
that little bit lower for handling as stated.
Anonymous
Posted: 2011/6/12 7:09  Updated: 2011/6/12 7:09
They need to be x rayed and braced. Depends on each engineer you speak to for structural and load integrity. Mine was inspected for mounts and passed flying colors
D
Posted: 2011/6/13 2:18  Updated: 2011/6/13 2:18
Considering the height and skirt width of the L series
it would be handy but pricey mod to have for extra clearance.
PIGDOG
Posted: 2011/6/13 6:58  Updated: 2011/6/13 6:58
if i were to get that crossmember engineered. i'd just paint it up and lie....but thats just me
marc1200
Posted: 2011/6/11 2:54  Updated: 2011/6/11 2:54
Not too shy to talk
hey mate anychance of you measuring how high your mounts aer from the crossmember? top of mount to bottom of mount? cheers
