Main : Misc A series
[<   Previous  4573  4574  4575  4576  4577  4578  4579  Next   >]
A series
A seriesPopular
SubmitterAutokatMore Photos from Autokat   Last Update2006/5/7 14:13    Tell a friendTell a friend
Hits2690  Comments5    0.00 (0 votes)0.00 (0 votes)
Other side
Dodgeman
Posted: 2006/5/7 14:33  Updated: 2006/5/7 14:33
 Re: A series
Y' know,...I think that this just might be an A10 engine.
Why?
The front distributor makes it either A10 or 1200, so we can rule out all other A series engines.
1. The front face of the oil pan does not have the vertical ribs that the 1200 has, but is relatively smooth like an A10 pan.
2. It looks to have a two piece metal fan like an A10 one. 1200's had a plastic fan.
3. It's hard to tell for sure, but in the photo of the other side of the engine, there is no crankcase breather pipe that comes out from the block at the back. It could have been removed & the hole plugged, but A10's never had a pipe there at all.
4. The distance between the highest point of the timing case & the bottom of the head is VERY small, but on a 1200 block, the head sits about 12 to 15mm higher than the timing case. Thats because the deck on the 1200 was raised to accomodate the increased stroke of this engine. The A10 has a 59mm stroke while the 1200 has a 70mm stroke.
Food for thought.
Autokat
Posted: 2006/5/7 14:49  Updated: 2006/5/7 14:49
 Re: A series
And it's sitting next to a 1000 race car
TnPshow
Posted: 2006/5/8 13:40  Updated: 2006/5/8 13:40
 Re: A series
Right you are:
I know I want one... hang on I've got two!
sidedraught
Posted: 2006/5/8 14:01  Updated: 2006/5/8 14:01
 Re: A series
That is one of the coolest cars on this site.
The KB10, you know you want one.
Posted: 2006/5/15 5:07  Updated: 2006/5/15 5:07
 Re: A series
Looks like Dman is right about it being an A10
from our man in Japan
Also
other side
Dodgeman
Posted: 2006/6/11 6:42  Updated: 2006/6/11 6:42
 Re: A series
Yep, that's an A10. There is no provision at the back of the block for the PCV pipe & the A10 was the only one that never used it.
greendog
Posted: 2006/5/7 14:19  Updated: 2006/5/7 14:19
 Re: A series
wonder if this engine will ever make it into a bay ever?i would keep that in my loungroom if that was mine.wouldnt think u would use vaccum advance but?
