Main : Members : 2QK4U Fibre Gasket
[<   Previous  30  31  32  33  34  35  36  Next   >]
Fibre Gasket
Fibre GasketPopular
Submitter2QK4UMore Photos from 2QK4U   Last Update2006/5/10 3:34    Tell a friendTell a friend
Hits2453  Comments3    0.00 (0 votes)0.00 (0 votes)
needed replacing as the old one was cracked, $14 from nissan.
greendog
Posted: 2006/5/10 12:35  Updated: 2006/5/10 12:35
 Re: Fibre Gasket
would cutting the middle out of that(between the two holes) make a difference u reckon?looks as though uve already done that to the manifold.
2QK4U
Posted: 2006/5/10 12:43  Updated: 2006/5/10 12:43
 Re: Fibre Gasket
no idea, got it from nissan like that so i dont wont to fiddle with it - they made it like that for a reason probably.
Posted: 2006/5/10 17:44  Updated: 2006/5/10 17:44
 Re: Fibre Gasket
The primary purpose of the plastic spacer is heat isolation. It keeps the carb from overheating.
The plastic spacer is designed to extend the carb bores, so don't cut the center out of it. Newer ones use an extender on the primary (a metal tube goes in the plastic spacer). This extends the bore down close to the floor of the manifold. It makes a huge difference in driveability--for the better.
2QK4U
Posted: 2006/5/10 23:13  Updated: 2006/5/10 23:13
 Re: Fibre Gasket
see i knew there was a reason for it. thanks mate.
