Main : Misc Engine Mount - Cortina - Kelpro MT8158N
[<   Previous  4408  4409  4410  4411  4412  4413  4414  Next   >]
Engine Mount - Cortina - Kelpro MT8158NPopular
SubmitterCable_TieMore Photos from Cable_Tie   Last Update2006/6/13 7:01    Tell a friendTell a friend
Hits3219  Comments4    0.00 (0 votes)0.00 (0 votes)
Used by many. . .
70mm in Diameter
37mm Tall.
~$52 each 9/6/06
Cable_Tie
Posted: 2006/6/13 6:43  Updated: 2006/6/13 6:43
 Re: Engine Mount - Cortina - Kelpro MT8158N
I *think* they are late model cortina, front engine mounts for the 250 x-flow (4.1L 6cyl)
Picked them up from repco, just give them the Kelpro Part Number (MT8158N)
Hope this saves some hunting.
Freak
Posted: 2006/6/13 7:17  Updated: 2006/6/13 7:17
Are these a direct swap for the standard mounts?
Cable_Tie
Posted: 2006/6/15 0:43  Updated: 2006/6/15 0:43
Did a quick measure up of a saggy standard mount last night.
It appears that the standard mount is 5mm taller at 42mm. The bolt it also offset by 10mm. (Warning: Old mount)
The bolt on the cortina mount is also larger.
I have been using 2L Mazda mounts for a few years that are basically the same. Just redrill the hole where it is needed.
LittleFireyOne
Posted: 2007/5/31 12:28  Updated: 2007/5/31 12:28
Just thought I'd share some more info on this too. Was at work srumaging though parts and I found a different mount that looks like this. Only difference may be the dimensions and it has a lcating stub on each side but I'll get a photo of it tomorro.
It's a Kelpro MT8261N , made for Volvo 240 4 cylinders from 74-78. Bummer it retails for like AU$83
