Main : Misc : Forum Dialling in new camshaft.
[<   Previous  332  333  334  335  336  337  338  Next   >]
Dialling in new camshaft.Popular
SubmitterLemonheadMore Photos from Lemonhead   Last Update2006/7/14 12:14    Tell a friendTell a friend
Hits3346  Comments6    0.00 (0 votes)0.00 (0 votes)
Setting cam to specs.
nzdatman
Posted: 2006/7/16 9:28  Updated: 2006/7/16 9:28
 Re: Dialling in new camshaft.
trying a new cam Gary?
Lemonhead
Posted: 2006/7/17 11:20  Updated: 2006/7/17 11:20
Spot on Dodgeman is one of the Nismo competition pumps, bought it of ebay/member a little while back.
It has not been the easiest things to fit because it fowls with the alternator mount, I think they were designed for the 1200 block which has the alternator on the passengers side, I've nearly got it to fit.
Yes I've had to put a new cam in the motor because the lobe on inlet No.2 pot was about half worn out, this would explain the lack of power i've had for the last few events.
I've gone for a cam with 107deg lobe seperation, 246deg duration @ .050" lift and just under 1/2" valve lift. The cam has been undercut to get this and then nitrided.
I really can recommend a company called Sure Cam for any A series cam work, speak to Phil Duggin, 07 3352 4777, he really knows his stuff.
While the motor was apart I got the block hot dipped to get rid of some of the scum, honed and new rings and bearings.
I started it yesterday and was glad to see the motor idle smooth again at 1200rpm.
I've got an event at the end of the month at Rockhampton so I need to get it run in and soughted by then. I can't wait to get it back on the dirt and have some power back again
blofly
Posted: 2006/7/17 11:58  Updated: 2006/7/17 11:58
so what does it mean when someone says they have a 54/86 cam? how do I translate those figures into lift, lobe seperation, duration, etc.
When you dial a cam in if the spec sheet says intake opens 23 degrees btdc does that mean I would use two dial gauges, one to measure piston TDC and the other resting on the intake cam lobe while I rotate it to suit 23 degrees on the degree wheel? is that how it works? I have never done one before and I have a new cam, head and carbs to bolt on
Lemonhead
Posted: 2006/7/14 12:17  Updated: 2006/7/14 12:17
Perfect place to put ones beer so as not to spill it.
Freak
Posted: 2006/7/14 12:24  Updated: 2006/7/14 12:24
Thats how we can measure bore sizes from now on. Yours appears to be 1 and a 1/4 beer bottles. note-does not include cooler. lol
rally1200
Posted: 2006/7/14 14:23  Updated: 2006/7/14 14:23
looking good. what oil pump is that.? and what spec cam are you going with.
B120dat
Posted: 2006/7/14 14:49  Updated: 2006/7/14 14:49
Sneaky datsun racing jacket in the background I can see ...
Dodgeman
Posted: 2006/7/15 0:24  Updated: 2006/7/15 0:24
Poster: rally1200 Date: 2006/7/15 0:23:36
It looks a bit like one of these.
The pump pictured below is a Nismo competition unit
