[< Previous 4199 4200 4201 4202 4203 4204 4205 Next >]
Clutch master side shot
kululadotgroen 2006/8/3 8:46 Tell a friend
3641 5 0.00 (0 votes)
| Sorry for the long absense, here's just another view of the mod for the clutch. Chopped of the end of the pedal, and welded back a piece of 4mm stock and redrilled the hole for the swivel pin. |
| Poster |
Thread |
| WhiteSedan |
Posted: 2006/8/3 12:09 Updated: 2006/8/3 12:09 |
No life (a.k.a. DattoMaster)   Joined: 2004/7/15 From: Adelaide, Australia Posts: 3931 |
 Re: Clutch master side shot Do you think theres room under there for both brake and clutch master if i was to run both of them with remote filler bottles.
Ive got clutch and brake masters from a Nissan Urvan which i might look at doing this with.
| Poster |
Thread |
| kululadotgroen |
Posted: 2006/8/14 13:26 Updated: 2006/8/14 13:26 |
No life (a.k.a. DattoMaster)   Joined: 2006/7/12 From: Cape Town ZA Posts: 1054 |
 Re: Clutch master side shot SHould be more than enough space, you'll prbably just have to change the brake pedal quite a lot on top.
| Poster |
Thread |
| WhiteSedan |
Posted: 2006/8/14 13:37 Updated: 2006/8/14 13:37 |
 Re: Clutch master side shot Excellent, thankyou very much! Do you think you could use a clutch pedal as a brake pedal to make modification easier?
| Poster |
Thread |
| kululadotgroen |
Posted: 2006/8/18 8:35 Updated: 2006/8/18 8:35 |
 Re: Clutch master side shot If you take into account that the clutch pedal is shape as almost a negative of the brake pedal, then no. I think you should be able to just weld a piece of 4mm stock ontop to change the pedal direction ie. to make it puch towards the inside of the car.
| Poster |
Thread |
| WhiteSedan |
Posted: 2006/9/13 15:08 Updated: 2006/9/13 15:08 |
 Re: Clutch master side shot No worries, i may look into this tomorow, i have a remote clutch assm for my L-series and it still uses the cable to actuate the master, very simple but heavy and its mounted up near the battery tray.
