Main : Mechanical : Brakes boosted in blue
[<   Previous  271  272  273  274  275  276  277  Next   >]
boosted in blue
boosted in bluePopular
Submitter3RotorMore Photos from 3Rotor   Last Update2006/8/29 23:48    Tell a friendTell a friend
Hits2747  Comments6    0.00 (0 votes)0.00 (0 votes)
this lady had drums all round.... SO... obviously that had to make way for something beter, and I thought it to be best to go as big as I can go.... VW Caravelle vented disks to be exact. Needless to point that the std 13" rims don't fit so lekker any more  :)
3Rotor
Posted: 2006/8/30 21:32  Updated: 2006/8/30 21:32
 Re: lekker -> well -> nicely -> etc...............
But I'm sure everyone kinda got the Idea what it ment.....
cheater_5
Posted: 2006/8/25 23:00  Updated: 2006/8/25 23:00
 Re: boosted in blue
hmmmmmm im interested. what had to be done to make em fit ??
also what sieze rims are you running now that the 13's arent fitting.
NICE car too, me likey a lot.
3Rotor
Posted: 2006/8/25 23:20  Updated: 2006/8/25 23:20
 Re: boosted in blue
well, the disk in question as baught from the parts store was about 10mm to big to fit into a 14" rim, wich was what I was going to be using, so I mashined it down. The calipers are your std floating single pot variety, as from any Toyota late model that runs vented disks, in my case, the Camry. getting the calippers to fit was the hard part, but not that bad.
You will also need to drill holes for the 4 studs, as the disk has 5 holes, fortunately one of the existing holes can be used as it is on the same PCD. I had to spces the rim quite a bit, in order to clear the shock, as can be seen.
I'm not running a booster, so the brakes are a tad bit hard.... but they are there with all the required force when you step on it.....Good brakes to me is way more important than a fast engine.
WhiteSedan
Posted: 2006/8/30 11:05  Updated: 2006/8/30 11:05
 Re: boosted in blue
They look identical to the 280zx brakes im running. I cant fit 13's either
2QK4U
Posted: 2006/8/30 11:13  Updated: 2006/8/30 11:13
 Re: boosted in blue
ahhaha 3rotor these Aussie's dont know what lekker means bru
WhiteSedan
Posted: 2006/8/30 11:15  Updated: 2006/8/30 11:15
 Re: boosted in blue
Eh lekker?
2QK4U
Posted: 2006/8/30 11:16  Updated: 2006/8/30 11:16
 Re: boosted in blue
hahah Afrikaans for Nice mate.
Mildman
Posted: 2006/8/30 12:04  Updated: 2006/8/30 12:04
 Re: boosted in blue
Useless fact no 143: Lekker is also german for 'tasty'
