B310 DISK BRAKE ROTORS REPLACEMENT
From LISBOA, PORTUGAL
Hello eveybody
I need to replace my B310 brake disk rotors and yesterday I tryed to do it. However I realized until now that it is needed to take the whell hub and the bearings off (so I did it). Behind the rotor there are 4 screws that I tooked out. Now it seems that disk has put there with a press or something. Impossible to pull out. Have everyone dealt with this situation previously?
Thanks.
Ricardo
Posted on: 2003/5/2 20:31
Re: B310 DISK BRAKE ROTORS REPLACEMENT
From Fort Worth, Texas, USA
It is a snug fit and they are probably a bit rusty. Once the four bolts are removed from the back side, the rotor should come off of the hub with a little persuasion.
Posted on: 2003/5/2 22:55
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From sydney australia
hiya ricardo,yes they are a tight fit,so you'll need a press.the new ones should go on with a light pressure from the wooden handle of a hammer,or a wooden hammer.
Posted on: 2003/5/5 13:55
thank you. So it is like I supposed. By now I am getting mad with my B310 driveshaft since the joint are weared out. I am going to the junkyard get a new one. Thanks to the driveshaft, the gearbox secondary shaft bearing is getting busted. Something like more than 1mm of radial play. I am going to get a gearbox as well.
Ricardo
Posted on: 2003/5/5 16:47
