A15 crank in A14 engine
Hi, Hopefully a quick and easy question..
I have my existing A14 engine stripped down, rebored and with new bearings etc ready for rebuild, i came across an A15 in a scrapyard going for a song....so i bought it for spares.
Looking at the excellent tech wiki on this site it seems to me i can just put the A15 crank into my A14 engine and doing so will give me the extra torque of the A15.....
is it that simple? or are there other considerations.. ?
I read somehwre that the block casting was different for the A15....
Posted on: 2012/10/1 8:37
Re: A15 crank in A14 engine
From Melbourne, Australia
should go staright in, just check clearance around the bottom edge of the block, where the sump bolts on, for clearance when rotating the crank, and to be safe use the a15 sump pan as it has a little extra clearance also
Posted on: 2012/10/1 8:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Portland OR. USA
Don't forget that if you put in the A15 crank, you will need to put in A-15 pistons. Crank pin is higher in the A15 piston to account for the longer stroke.
Posted on: 2012/10/1 14:13
Ahh, different pistons...... hadnt anticipated that, although thinking about it, maybe i should.....I already got new A14 pistons to match my rebore.....
Posted on: 2012/10/1 15:03
Not yet checked out the price of new A15 pistons,.. but just so i know.. is it possible to machine the top of the A14 piston by 2.5mm ? then in theory it would be the same as an A15...
My new A14 ones arent original nissan items but some locally made copies.. so i'll need to have a good measuring session, but has anyone ever done this ?
Posted on: 2012/10/2 7:59
if they are local made copies i'm guessing they wern't expensive, you shouldn't lose much money on selling the ones you have and just buying the correct ones?
Posted on: 2012/10/2 8:28
1200 Coupe Rallycar
yes, youre probably right... new pistons will be the way to go, i also bought new pins and had them pressed in by the machine shop but i think they can be reused on a new set of A15 pistons....
The machine shop actually supplied the A14 pistons and rings when they did the rebore... i'll see if i can get them to swap them over...
providing of course the old A15 crank is ok once i strip it out....
another thought... how about the compression ratio, this must increase slightly due to the extra volume, but using the same head as the A14 (although my understanding is that thats how they came from the factory).
Also, is my carb (currently the std Hitachi downdrauft) likely to need re-jetting ?
Thanks for your help..this is my first engine rebuild....
Posted on: 2012/10/2 8:44
From Near Bundaberg QLD
Standard Hitachi Downdraught carbies work on all standard A-series engines, A10 thru to A15, so it should be fine
Posted on: 2012/10/2 10:34
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
stock a15 jets smaller than a12. most people put a12 jets in stock a15 carb
Posted on: 2012/10/2 11:41
1200 Coupe Rallycar
From Perth
You will find the 15 piston has more dish than the 14 piston to keep the compression ratio around the same (8.5:1)
Unless your able to get a flat top or one with less dish to bring them up to a more desirable 10:1
I've run an A15 crank in an A14 block for years
Posted on: 2012/10/2 14:49
