0 degrees on the cam cover means TDC, right?
I'm 90% sure that's right, but before I do anything stupid: if the timing mark is set at 0, that means cylinder 1 is at TDC.
I'm setting up a DIY spark controller with a ford EDIS spark module and I want to make sure I at least have the initial hardware correctly positioned.
Thanks for any advice
Posted on: 4/7 5:20
Re: 0 degrees on the cam cover means TDC, right?
Yes, that's right. 0 means TDC for piston #1
With a distributor, you need to know which TDC (compression stroke or exhaust stroke) but with wasted spark i think it's irrelevant
Posted on: 4/7 9:06
Cool, thanks. Wish me luck!
Posted on: 4/12 19:54
