What tranny with Sr20det swap
From EUPEN / BELGIUM
I just bought a 1200 and an 1600 A10 from Portugal.
I'm in Belgium.
What tranny, gearbox have I got to use with the Sr20DET swap. Can I use the SR20DET one?
Posted on: 2004/1/23 19:13
Belgian Roadster
SRL 311 69'
1200 SR20DET swap started
Re: What tranny with Sr20det swap
I forgot, the swap is for the 1200
Posted on: 2004/1/23 19:20
From Warwick, QLD
yeah you could use the SR20DET box but there may be clearence issues between the box and the trans tunnel, which if your hands with a welder and metal then modifying the tunnel shouldn't be that hard.
Cheers
Damo
Posted on: 2004/1/24 0:07
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Millgrove Vic OZ
There is aproblem with the length of the SR20DET box. The shifter is too far back towards the rear of the car. A better idea is to get an MR30 box and fit the SR bell housing. This is a lot shorter.
Posted on: 2004/1/26 6:39
Cheers Feral
From Canberra
We are currently completing the conversion on a 1200 ute and you will have issues with the trans tunnel being too narrow. We have completely refabricated a new trans tunnel, we are lucky we know an excellent welder! I will post a pic up when I get home.
The shifter does sit further back but that hasnt presented too many problems. The handbrake has been moved and it seems ok now. I had the same problem on mine when I decided to change from a MR30 box to a S13 box but a quick change of the handbrake position and it was ok.
Posted on: 2004/1/28 21:57
www.valvebounce.com
motorsport and performance forum
From Canberra
Posted on: 2004/1/31 12:34
www.valvebounce.com
From Arlington, TX, USA
Can't really see the shifter?
Is it that lump in the middle?
Posted on: 2004/1/31 14:45
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Canberra
Damn sunlight, yeah thats where the shifter pops through. Where it runs flat. The ute will be running a rebuilt S13 SR20DET with the same mods on my CA (GT28, EMS, FMIC, Borg Warner etc).
Posted on: 2004/2/1 6:12
www.valvebounce.com
What is the welded box under the dash, the one with the small welded arms?
Posted on: 2004/2/6 20:54
Belgian Roadster
SRL 311 69'
From Canberra
Due to the size of the engine and lack of room we decided to extend the firewall so we were able to fit a decent intercooler, radiator and thermos. The welded box is where the firewall has been moved back, the welded extension on the left is due to the dump pipe on the turbo.
Posted on: 2004/2/7 2:36
www.valvebounce.com
