Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Real handling from a datsun 1000
s13drifter
Posted on: 2004/8/25 8:57
Okay can some of you guys outline how to get reall handling from my datsun 1000.... i lowered it a little at the front which is much better but i want more.... i want some neg camber and good shocks and everythin i can to make me un-catchable through a corner, oh and i know better tyres are a key as well!!!! But what can i do??
Cheers, Daniel
#2
Re: Real handling from a datsun 1000
Dodgeman
Posted on: 2004/8/25 11:19
OK
What was the method of lowering the front, &,... is this a street car, or a racer? I found that fitting a front sway bar was helpfull. Good shocks are always a good idea. You will find that the 1200 coupe copied the 1000's rear shock setup, so don't go looking for Koni's for a 1000, look for them for the 1200 & 120Y coupes. I'm told that you can convert LC & LJ Torana front shocks for use on the 1000. I hope so as i have Konis for these as well, with the intention of using them on my coupe. Unlike the later cars with pogo stick suspension, you can adjust ALL aspects of the wheel alignment in a non destructive way with just a standard wheel alignment procedure. The 1000 has a real suspension. Edit OK, i checked, it's for street use. Don't get too carried away with the handling thing as it doesn't take much for these things to be quite good, & it doesnt take much to make a mess of ride quality & tyre life either.
#3
s13drifter
Posted on: 2004/8/26 4:40
The method in which i lowered the car was simply to cut the rubber stopper 3/4 of an inch...
I assume for the back a lowered harder spring and some good shocks would be the go??? I am also interested in way an LC torano couldnt i just measure the size the shock has to be and tell koni to give me shock that will fit!!! Yes it will be a street car, ride doesnt particulaly bother me overly i drive go garts so any car that i hop into always feels luxurious!!! Thanks for the response!!!
#4
dattoman_1000
Posted on: 2004/8/26 11:52
If I remember on the weekend I'll try to get pics of my torana shocks on the front of my 1000 coupe.
Monroe Gas with modifications They don't go straight on but its not too hard to adapt them The compressed and extended lenghts are close enough to work Later I'll get details of my coilover setups for front and back. But you'll have to wait till I finish those.
#5
dems
Posted on: 2004/8/26 22:24
how did you get the rubber stopper out? i tried heaps and in the end I couldnt lever the springs up enough to get the rubber out.
#6
datto_ute
Posted on: 2004/8/26 23:02
.....spring compressors are a wonderful thing......
#7
dems
Posted on: 2004/8/26 23:15
talking about leaf springs here dude
#8
L18_B110
Posted on: 2004/8/26 23:45
how did you get the rubber stopper out? i tried heaps and in the end I couldnt lever the springs up enough to get the rubber out. you need to 'drop' the balljoint. I lowered my old 1000 coupe with the traditional reverse leaf method - even at the front. This increases spring rate also. Lowering by simpy cutting the pad away while keeping standard spring rates won't improve handling much in itself, and could easily result in alot of bottoming out. I have also heard of a single leaf out of a landcruiser pack being used on the front of a 1000. But I suspect it was also reset to achieve the desired ride height. You can view topic.
