Question for CA18DET Guru's
From Mandurah, Western Australia
On the CA there are 4 vacume lines which come out between the inlet manifold on the drivers side of the motor. They go to a canister and some one way valves.
What exactly is this canister used for on the s13?
I thought it was for the climate control, being a vacume resovoir to assist in the switching of the solenoids required for electronic climate control systems. Is this correct?
I ask as I came to the above conclusion and removed it from the CA conversion process, halfway through. But I have noticed in a few pix I have seen this device remains.
So what exactly does it do and is it needed?
Posted on: 2007/8/8 3:24
Subject Poster Date
     Question for CA18DET Guru's old_school 2007/8/8 3:24
       Re: Question for CA18DET Guru's dattodude 2007/8/8 10:37
         Re: Question for CA18DET Guru's perthute 2007/8/8 12:31
           Re: Question for CA18DET Guru's BUNDY351 2007/8/8 12:51
             Re: Question for CA18DET Guru's perthute 2007/8/8 15:27
               Re: Question for CA18DET Guru's BUNDY351 2007/8/8 15:39
                 Re: Question for CA18DET Guru's old_school 2007/8/9 1:15
                   Re: Question for CA18DET Guru's old_school 2007/8/9 1:21
                     Re: Question for CA18DET Guru's old_school 2007/8/9 1:26
                       Re: Question for CA18DET Guru's old_school 2007/8/9 3:07
                         Re: Question for CA18DET Guru's dattodude 2007/8/9 10:00
