Browsing this Thread:
1 Anonymous Users
Gear Drives .. |
From Sydney, Australia
anyone know if u can get gear drives for an a14/15? I got hooked on the sound when i had my old EH wagon. thanks, Linc.
Posted on: 2001/5/11 4:38
Re: Gear Drives .. |
Linc I presume you are talking about cam gear and therefore no. I am still working on the idea of using the E15 bits and although it looks more complicated than I first thought I have still not dismissed it. This is of course a belt drive system. They can sound good also. What I do have and am working on is setting up a gilmer drive for the auxillary pulleys. I am going to graft the outer of a Fiat cam pulley into the inner of the A crank pulley. Use a E15 crank pulley, the little one on the crank for the alternator and then maybe buy a water pump pulley or graft one on from say the E15 idler which is in the A15 cam position. On the E15 it drives the fuel pump and acts like an idler. Then it will just be a matter of finding the right length belt. Unfortunately this is not a priority at present. If you are keen the Mini's now have a gear drive which may be adapted but that would be expensive. What about from the Holden range.Someone once told me that some people were using Holden drives on the A series but didn't have all the details. It is obviously a made up thing has anyone ever heard of this.
Posted on: 2001/5/11 7:42
