Starter motors
From New Zealand
was having a look at a few a series starters today and noticed that some had 8 teeth and some had 9. I thought all starters were interchangable, so does different ring gear/flywheel size on a12-a15 overcome the extra tooth?? i've never taken any notice of this before, would hate to munch my flywheel!!
Posted on: 2008/12/12 3:06
Re: Starter motors
From Adelaide, Australia
All interchangeable as far as I know. I have swapped over many an a-series start motor without any problems ever.
You'll find they are the same size and pitch teeth, so the 9 tooth gear would be larger and offset further away from the flywheel to compensate.
Posted on: 2008/12/12 5:47
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Starter motors
From New Zealand
i thought it must be something like that, because i've interchanged a12 and a15 starters as well, just never taken any notice of the number of teeth before. I must have been really bored!!!
Posted on: 2008/12/12 21:05
Re: Starter motors
* starters for all A-series engines interchange
* starters for automatic vs manual transmission differ
See datsun1200.com Starter article
Posted on: 2008/12/12 22:22
Re: Starter motors
From Armidale N.S.W
Well the starter motor in my A14 wont fit me A12 and there both 4 speed manuals. The one in my A14 has a notch that wont allow them to go in the A12. The A14 is out of an early pulsar if that makes a difference but i doubt it. We have about 3 0f each. also the A14 ones i have are noticeably bigger.
Posted on: 2008/12/13 1:00
73 1200 wagon SOLD
Re: Starter motors
It's probably because it is a Pulsar (fwd) car. I put the bigger one on my A12.
Posted on: 2008/12/13 10:22
