(1) 2 3 4 ... 8 »
Negative Camber
Quite a regular
From Hartswater South Afrika
Hi there
Is there anyone that can tell me if there is any way i can get my 1200 gx to a negative camber without changing the lower control arms,I can seem to find strut top adjusters in ZA
Thanks
Posted on: 2009/1/17 18:24
Re: Negative Camber
Quite a regular
OH,and how many degrees of neg. camber will be needed on a gymkhana kar
Posted on: 2009/1/17 18:36
Re: Negative Camber
* Slot the strut tower bolt holes -- recommended by Datsun Competition
or
* Fit a B310 ball joint and B310 tie rods
or
* Fit offset LCA bolt
See Suspension Upgrades, section "Negative camber"
Posted on: 2009/1/17 19:14
Re: Negative Camber
From Christchurch NZ
If you want a modest increase, use the Longer B310 ball joints. You'l need to use Later model ute steering arms to accomadate the larger daimeter ball joint taper. Youl'll then need either ute or b310 lower arms, and castoer rods. (As DD said)
Posted on: 2009/1/17 19:41
Forced Induction!
Re: Negative Camber
From Nyngan, nsw Australia
maybe try this........
using this camber bolt....
Posted on: 2009/1/17 19:46
living is good,.....
Re: Negative Camber
From Brisvegas, oz
why dont you just buy the camber tops that are sold on australian ebay then have them shipped to you. one of the members on this forum makes them
Posted on: 2009/1/17 23:23
www.camerasplus.com.au
Re: Negative Camber
modifing you lower control arm pivot point, you'll run the risk of inducing bump steer.
Posted on: 2009/1/18 5:22
Forced Induction!
Re: Negative Camber
Quite a regular
Thanks to all , going to try to get the strut tops from aus. If that does not work i will do the ball joint thing.
Posted on: 2009/1/18 10:42
Re: Negative Camber
Quite a regular
How much negative camber do you guys think i am going to need for gymkhana?
Posted on: 2009/1/19 8:09
Re: Negative Camber
As much as you can get, especially is the suspension is otherwise stock.
Posted on: 2009/1/19 8:11
(1) 2 3 4 ... 8 »
