CA oil lines, got some finally.....but
From Geelong, Vic
it looks like there is some kinda fitting that i need to go into the block on the passengers side so that it can actually adapt to the oil line
as the bolt thread is like 1/8th npt or bsp....what ever the oil pressure sendor thread is. and the oil line has a nut on the solid line like what a brake line would have, but its about a 12mm or so thread.
it all seems to go in the right place so it just looks like theres a 90 degree fitting thats supposed to fill the gap
is this correct, if so does anyone have a spare one of the said fitting?
or if anyone has pics of the oil feed so i can make sure this is the right thing
this is one of the last things i need to get the CA done as i have a week off uni after easter and want to get the CA in and running
Posted on: 2009/4/7 10:53
Subject Poster Date
     CA oil lines, got some finally.....but PIGDOG 2009/4/7 10:53
       Re: CA oil lines, got some finally.....but Anonymous 2009/4/7 12:03
       Re: CA oil lines, got some finally.....but dattodude 2009/4/7 12:45
       Re: CA oil lines, got some finally.....but blob 2009/4/7 20:06
         Re: CA oil lines, got some finally.....but dazza1200 2009/4/8 0:48
           Re: CA oil lines, got some finally.....but datpro1 2009/4/8 3:34
       Re: CA oil lines, got some finally.....but PIGDOG 2009/4/8 5:26
       Re: CA oil lines, got some finally.....but PIGDOG 2009/4/8 6:06
       Re: CA oil lines, got some finally.....but dazza1200 2009/4/9 1:10
       Re: CA oil lines, got some finally.....but PIGDOG 2009/4/9 3:09
