#1 Borg Warner 68 series.
Rezlo Posted on: 2009/8/26 20:17
All happy I managed to find two Borg Warner 68 series diff's today, one from an Escort with 4.1 ratio and one from a Stanza with 3.7.
Strip them, Stanza is rusted beyond usage, escort isnt to bad but both have enclosed spiders making the Posi style LSD insert impossible.
Well so much for that idea...
jpg  Fail 1 (Large).JPG (125.01 KB)
9082_4a958a10cf699.jpg 1024X768 px
jpg  Diffs (Large).JPG (107.05 KB)
9082_4a958a27e8a80.jpg 1024X768 px
jpg  stanza (Large).JPG (90.97 KB)
9082_4a958a3f96d4d.jpg 1024X768 px
jpg  escort (Large).JPG (118.98 KB)
9082_4a958a56c6944.jpg 1024X768 px
#2 Re: Borg Warner 68 series.
racetech Posted on: 2009/8/27 7:41
That stanza diff is unusable.
We stripped the spiders on the escort a while ago, what a pain in the arse to get to the gears.
Rezlo so the question being, will something like n phantom grip be possible in one of these diffs.
The other question I still have, is the diffs in England the same as the ones in RSA, the reason for asking this, Quaife does a insert for the escort diffs, crap expensive, but the real question is, will it fit in our SA diffs.
#3 Re: Borg Warner 68 series.
Rezlo Posted on: 2009/8/27 8:16
No, british diff is front access as with the H series datsun diff's. does not work/fit in our borg warners.
I highly doubt one will be able to fit a posi setup (phantom grip) into the BW with closed center as above
#4 Re: Borg Warner 68 series.
racetech Posted on: 2009/8/27 8:48
At the end of the day, it just gets worse for us in RSA
#5 Re: Borg Warner 68 series.
racetech Posted on: 2009/8/27 9:00
What the bunch of us in RSA should do is keep our ears on the ground and find a strong diff that doesn't need shorting to fit the ute's and 1200's and a local lsd inserts is available. Then we just need to safe our money and buy these units.
But then again, easier said than done.
Rezlo thanks for the research on these diff units, much appreciated, know we all are in the loop.
#6 Re: Borg Warner 68 series.
WhiteSedan Posted on: 2009/8/27 9:11
Alfa diffs some of the RSA boys have been running, they have a LSD alloy centre... I'll find a link.
#7 Re: Borg Warner 68 series.
Rezlo Posted on: 2009/8/27 9:26
Finding an alfa diff is the problem, and when you do either they want $1000US+ or its stuffed, usualy the later.
#8 Re: Borg Warner 68 series.
Rezlo Posted on: 2009/8/27 14:21
after all this it might be easier just shortening an M75 out of a venture, it has a clutch LSD
#9 Re: Borg Warner 68 series.
superbin Posted on: 2009/8/27 14:29
As far as I know only some of them came out with those diffs
#10 Re: Borg Warner 68 series.
racetech Posted on: 2009/8/27 14:49
I'm looking for specs on these M75 units, but no luck yet.
I emailed a company in Joburg that can supply them, but the answered everything besides what is the dimensions.
The reason I want it, is it really necessary to shorten it?
