(1) 2 3 4 5 »
#1 best way to get power steering?
ca18datsun Posted on: 2010/3/18 5:57
i own a ca18det datsun ute, i bought it less than a week ago.
im not too mechanically inclined, but i know i dont like using two hands everytime i turn right at a round about.
so whats involved, parts, labour, cost the lot. im based in nsw, thanks/mik.
#2 Re: best way to get power steering?
tongy Posted on: 2010/3/18 8:15
lift some weights
#3 Re: best way to get power steering?
ROConnor Posted on: 2010/3/18 8:29
HAHAHA gold.
#4 Re: best way to get power steering?
greendog Posted on: 2010/3/18 8:43
pump ur tyres up to 60 psi!.front tyres are to wide or the steering setup will make it feel heavy, what size tyre u running?maybe put an a12 in it
#5 Re: best way to get power steering?
DATUTE1 Posted on: 2010/3/18 9:23
That sounds odd. All my utes, albeit stock ones, are really easy to steer. Especially when its rolling. Maybe get your steering checked out at a steering place.
#6 Re: best way to get power steering?
sikyne Posted on: 2010/3/18 9:44
Power steering will not be be the answer.
I`d replace the idler arm bushes with urethane, use plenty of the grease that comes in the kit.
The biggest problem will probably be the caster setting. too much caster will make the car very heavy to steer.
And as already said, check your tire pressures. up to 40psi is ok.
Make sure all the tierod ends and the drag link are good aswell.
#7 Re: best way to get power steering?
ANGE Posted on: 2010/3/18 10:49
what size tyres do you run up front?
i feel a big difference between running 175's up front compared with 195's
#8 Re: best way to get power steering?
Posted on: 2010/3/18 20:32
run ouny 155's or 165s up front like me, easy as to steer.
#9 Re: best way to get power steering?
reuby_tuesday Posted on: 2010/3/18 22:16
I dont think that the 1200 anywhere in the world ever came with a power steering unit. Its possible that the Japenese may have done so (they have a go at everything), but certainly nothing here in australia.
With much nashing of teeth and removal of hair, you could make comething fit from somthing else. That would entail custom everything to fit an alien steering box, power steer pump,idler pulley, extra groove on the crank pully (a/c pulley would work), mount brakcets. hmm pretty extensieve job really, when the comments made by sikyne would be the first port of call.
Dont think anyone on this forumn has done it, cause the utes are not too heavy in the big picture. My first car was a SWB patrol with no power steer, and 12.5" wide tyres and Im a skinney bugger.
#10 Re: best way to get power steering?
ddgonzal Posted on: 2010/3/19 2:03
Who cares? Datsun 1200 doesn't need power steering. The factory never had it as an option, not even for the utes.
(1) 2 3 4 5 »
