#1 Nissan part number for FS5W60L reverse switch
benny Posted on: 2010/6/21 6:30
Does anyone have any B310 reference material listing the part number for the reverse switch in FS5W60L 5-speed tranmission?
cheers
benny
#2 Re: Nissan part number for FS5W60L reverse switch
ddgonzal Posted on: 2010/6/21 6:41
Same as FS5W60A, same as Datsun 1200 4-speed
32005-K102A SWITCH COMP-REVERSE LAMP
* replaced 32005-K1002/32005-K1002/32005-H5000
#3 Re: Nissan part number for FS5W60L reverse switch
benny Posted on: 2010/6/21 6:46
I dont think they are the same. I have tried a few switches from the other boxes I have. The reverse lights come on 1 through 5 forward gears and turn off when in reverse.
#4 Re: Nissan part number for FS5W60L reverse switch
benny Posted on: 2010/6/21 6:49
In most boxes the Switch pointer tip will be in contact with the selector rod and move off the ramp, when reverse is selected.
In my case, the selector rod comes into contact with the switch when reverse is selected. [Reverse being top left position, the selector rod moves rearward]
Most switches are typically "open cct" type so I hoping that there is a "closed cct" type somewhere.
edit: pic showing the ramp on the end of the selector shaft on the 1st /Reverse gear assembly.
#5 Re: Nissan part number for FS5W60L reverse switch
ddgonzal Posted on: 2010/6/21 6:57
oh yes you are right. The 5-speed uses another one. See http://datsun1200.com/modules/mediawi ... ssion#Reverse_Lamp_Switch
#6 Re: Nissan part number for FS5W60L reverse switch
Posted on: 2010/6/21 7:09
unless you are using the overdrive swithch?
not the reverse switch? i thought a series were same, L series is longer bu a series fits the sss dogleg box.
#7 Re: Nissan part number for FS5W60L reverse switch
benny Posted on: 2010/6/21 7:21
DD. The url points to listings for the 56 series. Is there one specific to the 60 series. I trawled through the WIKI over the weekend with no result. The part number must be somewhere....
#8 Re: Nissan part number for FS5W60L reverse switch
Cable_Tie Posted on: 2010/6/21 8:31
Normally Open, or Normally Closed when removed?
I got a bucket somewhere I could dig thru. . .
#9 Re: Nissan part number for FS5W60L reverse switch
ddgonzal Posted on: 2010/6/21 8:44
The 60L and 60A pn is listed in the 56-series article, don't ask me why.
Search and you shall find.
#10 Re: Nissan part number for FS5W60L reverse switch
bakat Posted on: 2010/6/21 9:53
in that case, if the proper switch is hard to find, i think you can use a relay that has the normally on function...
