Nissan part number for FS5W60L reverse switch
From Sydney
Does anyone have any B310 reference material listing the part number for the reverse switch in FS5W60L 5-speed tranmission?
cheers
benny
Posted on: 2010/6/21 6:30
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Nissan part number for FS5W60L reverse switch
Same as FS5W60A, same as Datsun 1200 4-speed
32005-K102A SWITCH COMP-REVERSE LAMP
* replaced 32005-K1002/32005-K1002/32005-H5000
Posted on: 2010/6/21 6:41
From Sydney
I dont think they are the same. I have tried a few switches from the other boxes I have. The reverse lights come on 1 through 5 forward gears and turn off when in reverse.
Posted on: 2010/6/21 6:46
1970 KB10 Coupe
S13 caliper b...
From Sydney
In most boxes the Switch pointer tip will be in contact with the selector rod and move off the ramp, when reverse is selected.
In my case, the selector rod comes into contact with the switch when reverse is selected. [Reverse being top left position, the selector rod moves rearward]
Most switches are typically "open cct" type so I hoping that there is a "closed cct" type somewhere.
edit: pic showing the ramp on the end of the selector shaft on the 1st /Reverse gear assembly.
Posted on: 2010/6/21 6:49
Edited by benny on 2010/6/21 7:34:53
Edited by benny on 2010/6/21 7:35:17
Edited by benny on 2010/6/22 0:38:10
1970 KB10 Coupe
S13 caliper b...
oh yes you are right. The 5-speed uses another one. See http://datsun1200.com/modules/mediawi ... ssion#Reverse_Lamp_Switch
Posted on: 2010/6/21 6:57
unless you are using the overdrive swithch?
not the reverse switch? i thought a series were same, L series is longer bu a series fits the sss dogleg box.
Posted on: 2010/6/21 7:09
From Sydney
DD. The url points to listings for the 56 series. Is there one specific to the 60 series. I trawled through the WIKI over the weekend with no result. The part number must be somewhere....
Posted on: 2010/6/21 7:21
1970 KB10 Coupe
S13 caliper b...
From Brisbane, Australia
Normally Open, or Normally Closed when removed?
I got a bucket somewhere I could dig thru. . .
Posted on: 2010/6/21 8:31
The 60L and 60A pn is listed in the 56-series article, don't ask me why.
Search and you shall find.
Posted on: 2010/6/21 8:44
From Malaysia
in that case, if the proper switch is hard to find, i think you can use a relay that has the normally on function...
Posted on: 2010/6/21 9:53
