Block height A10 (179.1mm) conrod 116.97mm to 117.3mm
Ive heard or read somewhere the a10 is 3mm shorter than the a12?
can anyone confirm this?
Im wanting to use the longer rods and bigger pistons for an E15ET
turbo with 20mm pins and need the later rods to fit with in the lil
bugger of a thing.
Posted on: 2010/7/5 11:27
Edited by D on 2010/7/5 12:29:00
Edited by D on 2010/7/5 13:33:04
Edited by D on 2010/7/9 10:10:11
Subject Poster Date
     Block height A10 (179.1mm) conrod 116.97mm to 117.3mm D 2010/7/5 11:27
       Re: anyon know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/5 12:28
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/5 14:52
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/5 23:57
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/6 0:01
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/6 0:39
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/6 9:50
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki Dodgeman 2010/7/6 14:43
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/6 15:45
           Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/7 1:56
           Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki Dodgeman 2010/7/7 16:47
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/8 2:59
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/8 7:19
           Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/8 7:26
             Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/8 11:03
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki ddgonzal 2010/7/8 20:32
         Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/8 23:57
       Re: any1 know the block height of an A10? A12 is 189.1mm in the Wiki D 2010/7/9 10:09
       Re: Block height A10 (179.1mm) conrod 116.97mm to 117.3mm ddgonzal 2010/7/10 3:40
       Re: Block height A10 (179.1mm) conrod 116.97mm to 117.3mm Dodgeman 2010/7/28 14:20
       Re: Block height A10 (179.1mm) conrod 116.97mm to 117.3mm A14force 2010/7/30 6:41
       Re: Block height A10 (179.1mm) conrod 116.97mm to 117.3mm D 2011/7/7 4:41
