Browsing this Thread:
1 Anonymous Users
help! A12 backfiring |
Hi guys I will try and explain my situation as best as i can as i am really stumped
My A12 is backfiring in my 120y it's not a fireworks type of backfire it's more of a popping sound near the carburettor but i can definately say it is coming from the exhaust manifold it sounds like a flopping and its only doing the flopping at idle and sounds clean and normal on load kind of like a misfire also i've found that richening out the mixture helps it alot for some reason which is wierd
what i've done so far changed carburetors, from hitachi to weber changed head gasket, reground the valve seats adjusted valves to .025mm i think if i can remember correctly changed leads, dizzy cap, rotor pulled the dizzy out to check for worn shaft, put back in to play with ign timing adv timing as far as i can then retarded when it sounded like a truck drained fuel and put a fresh batch in
what i suspect is: worn condensor and points as i havnt changed these before although im not 100% sure if its this or not would anyone know the symptoms of these when they go bad? fuel filter blocked? i doubt it as it's brand new vacuum leak? i hope not, i've done everything to eliminate this and sprayed carb cleaner to see if engine revs change and nothing does anyone have any other ideas?
Posted on: 2010/8/1 15:21
