Tyres
From Goulburn NSW
Hi guys,has anyone had anything to do with Nankang tyres?They are the only brand that do 135's for my front runners or is there another brand that I have missed?
Posted on: 2013/4/2 9:18
Re: Tyres
I have some nankang tyres here, im keen to know how they are too! they came with another car...
Posted on: 2013/4/2 9:21
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: Tyres
Don't drive in the wet
Posted on: 2013/4/2 9:23
Re: Tyres
From Goulburn NSW
Why? mate not wide enough,or are the tyres #OOPS#.
Posted on: 2013/4/2 9:27
Re: Tyres
From Narellan,Sydney
Front runners are terrible to drive on wet or dry.tgey struggle to turn.ohh and are illligal
Posted on: 2013/4/2 10:06
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Tyres
too narrow for any kind of front end grip but mainly any nankangs ive driven on are rubbish grip in the wet.
Posted on: 2013/4/2 10:36
Re: Tyres
From Cheltenham
had nankangs on the back of one of my old cars and only had them for about 2 months before i changed them due to ZERO grip in the wet
Posted on: 2013/4/2 11:19
Re: Tyres
From Brisbane
you will die with 135 on the front
Posted on: 2013/4/2 11:29
Re: Tyres
From Canberra
I run the 135 Nangkangs and I find them fine. Chances are if you're running them on your car it's going to be drag oriented so it won't be set up for taking corners like a circuit/hill climbs based car would anyway.
I find that driving sensibly that they are fine in all conditions. Obviously if you plough into a corner too fast the tendency is for it to under steer but at normal speeds I've never had a problem. Same in the wet, I'm more worried about the tail stepping out than I am about the front having troubles.
Posted on: 2013/4/2 13:18
YLD.18L
Re: Tyres
From Goulburn NSW
Hi Lachie im not planning on going around corners flat out,i only will give it a gutful in a straight line.Ok been looking around and found vintage tyres company,now looking at firestone are they a decent tyre?Gotto be better than phillipines made nankang.
Posted on: 2013/4/2 23:38
Edited by mcdat on 2013/4/3 1:21:27
