Hey dummy A15 uses a longer head bolt.
From Las Vegas USA
So after tugging the bottom end out of the car to fix the cam timing I screwed up, I discovered the A15 uses a different / longer head bolt for the oil hole. Sure it's in the tech section but what kind of fool reads directions? I nearly screwed up the threads in the block, the scary part is when I installed the head the first time I actually got the A12 "T" bolt tongue to 51ft lbs. (I had a new set of A12 "13" bolts) On the second go round it did not feel quite right. Sooooooo after looking at the bolts that came out of the A15, I noticed "hey dummy one of these is longer". I'm sure the engine builders cartel will send someone by the house to confiscate my tools.
This of course falls under your not in an A12 any more............. This is what I tell my Ego, being 98% driver it's quite fragile.
Tom
Posted on: 2013/4/27 5:59
Subject Poster Date
     Hey dummy A15 uses a longer head bolt. Rallytwit 2013/4/27 5:59
       Re: Hey dummy A15 uses a longer head bolt. ddgonzal 2013/4/27 6:28
         Re: Hey dummy A15 uses a longer head bolt. LittleFireyOne 2013/4/27 10:04
           Re: Hey dummy A15 uses a longer head bolt. darrenwilson 2013/4/27 15:50
             Re: Hey dummy A15 uses a longer head bolt. ddgonzal 2013/4/27 21:18
