#1 Camber Adjustment
Cody6936 Posted on: 2013/8/23 17:33
Hey guys, this question has probably came up many times. But I was wondering how do I achieve negative front and rear camber on my 1200 ute, for a "Stanced" look. Cheers
#2 Re: Camber Adjustment
darrenwilson Posted on: 2013/8/23 17:44
To achieve negative camber at the front you will have to get adjustable camber plates from s13 possibly 7 degrees and at the back because its a 'Solid diff' only way to get negative camber is irs
#3 Re: Camber Adjustment
Cody6936 Posted on: 2013/8/23 17:49
What modifications will be needed to fit s13 camber plates?
#4 Re: Camber Adjustment
ddgonzal Posted on: 2013/8/23 19:08
No modifications. There are several ways to achieve this. See Camber
#5 Re: Camber Adjustment
wards Posted on: 2013/8/25 10:47
you can have 3 deg neg camber on the rear with this cambered floater kit that I make for improved production cars , not cheap though with axles not much change out of $3000
jpg  IMG_0511.JPG (170.91 KB)
9512_5219d60709967.jpg 653X490 px
#6 Re: Camber Adjustment
ddgonzal Posted on: 2013/8/25 19:35
wow
