Browsing this Thread:
1 Anonymous Users
Camber Adjustment |
Quite a regular
From Victoria
Hey guys, this question has probably came up many times. But I was wondering how do I achieve negative front and rear camber on my 1200 ute, for a "Stanced" look. Cheers
Posted on: 2013/8/23 17:33
Re: Camber Adjustment |
From Trinidad and tobago
To achieve negative camber at the front you will have to get adjustable camber plates from s13 possibly 7 degrees and at the back because its a 'Solid diff' only way to get negative camber is irs
Posted on: 2013/8/23 17:44
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Quite a regular
From Victoria
What modifications will be needed to fit s13 camber plates?
Posted on: 2013/8/23 17:49
1982 Datsun 1200 Ute- Getting resprayed and partly shaved A15 Engine 5 Speed
Registered Users Contentmaster Usermaster
No modifications. There are several ways to achieve this. See Camber
Posted on: 2013/8/23 19:08
From windsor, sydney
you can have 3 deg neg camber on the rear with this cambered floater kit that I make for improved production cars , not cheap though with axles not much change out of $3000
Posted on: 2013/8/25 10:47
WARDMAN ENGINEERING CNC machining Race Car Fabrication Suspension, Brake, Drivetrain modification TIG welding of all metals 0413 595 627
wow
Posted on: 2013/8/25 19:35
