dual valve springs and stem seal issues
From vic
hi so i was checking my valve clearances out today and noticed an possible issue which could be causing blowby from my rocker cover at high rpm
the stem seals seem to not be seating on the guides but are on the top of the valve stem and sort of stuck in the inner valve spring.
not sure if this could be causing my blowby issue?
any thoughts?
Thanks!
Posted on: 2013/11/16 10:14
Subject Poster Date
     dual valve springs and stem seal issues a12datto120y 2013/11/16 10:14
       Re: dual valve springs and stem seal issues clyons8 2013/11/16 22:24
         Re: dual valve springs and stem seal issues ddgonzal 2013/11/17 5:48
       Re: dual valve springs and stem seal issues Rallytwit 2013/11/17 19:29
