Delta D5 camshaft
From Bridgetown, Barbados. W.I
Hello, would like some help getting specs on this camshaft. I have emailed delta but no luck so far.
Will be greatly appreciated.
Thanks.
Posted on: 2015/10/24 0:09
Life's better SIDEWAYS!!
Re: Delta D5 camshaft
Yes, better to telephone Delta. They have 8,500 profiles. They can also advise on the best profile for your needs (RPM, usage, etc).
Delta will regrind the camshaft, which means the lobe gets smaller. It is very important to install per their break-in recommendations to prevent excessive wear. Traditionally this means using special cam lubricant, NEW lifters, and not letting the engine idle below 2000 rpm for the first 20 minutes. Delta's procedure may be different as they parkerize the cam.
Posted on: 2015/10/24 0:55
Ok thanks.
Have the camshaft in a race prep engine I bought, just wanted to know the specs...
Posted on: 2015/10/24 10:54
