Bespoke A15 Turbo intake manifold
Thought some of you might like to see the A15 turbo intake manifold I just finished. Bespoke cast in A356 to suit weld on plenum. They are designed and made to order - runner length, position, taper etc all can be specced to suit the customers engine.
I can do these to suit any build, N/A ITB or turbo bolt on plenum etc. Will have a new full ITB kit coming in the next few months to suit A and L series.
Whitleytune A15 turbo manifold
jpg  1small.jpg (183.02 KB)
705_5d17f711e6bcb.jpg 800X600 px
Posted on: 2019/6/30 0:43
Re: Bespoke A15 Turbo intake manifold
From Zimbabwe
Can you make them to suit A15 and to bolt up to Toyota throttle bodies??
Posted on: 2019/7/3 9:58
No skool like the old skool
Yeah sure can. I'd recommend splashing out for new throttles if you are spending the money though.
Posted on: 2019/7/3 21:49
From Zimbabwe
I'm in South Africa so Toyota throttle bodies are easily available and a few guys have had good results with them. You got email address or WhatsApp number???
Posted on: 2019/7/4 19:34
Yeah send me an email, whitleytune@gmail.com
Cheers
Posted on: 2019/7/5 2:30
These units would also have been suitable for quad butterflys
which would eliminate alot of the cost of throttle bodies.
Posted on: 2019/7/7 1:32
From Creswell, Oregon USA
I really like these!
Posted on: 2019/7/8 3:40
D, the cost of machining the casting to suit throttles would cost more than using throttle bodies. Not an easy task to drill through 4 runners an accurate 8mm shaft hole and then counterbore for bearings plus finish boring the runners for butterfly seal etc.
Will have my A15 ITB kit out soon.
Posted on: 2019/7/9 1:16
So true better using bike itbs instead for cost saving
yet would still need 2 piece casting etc.
Nice looking units though, should be some happy customers
Posted on: 2019/7/9 14:45
