A10 block: the high performance A-series
The A10 Engine was the beginning of the A-series dynasty, so the beginning of the high-performance small Datsun engine. In the 1966 Datsun 1000 it was a revelation, a smooth high-revving powerplant.
At first glance it looks the same as the early A12 block, but it has 3 main differences:
* 3-bearing crankshaft rated at 6,000 rpm. The A12 has a stouter 5-bearing crank and can rev much higher (the GX was rated at 6400 rpm). But with the A10's very short 59mm stroke it doesn't vibrate much
* Deck height: 10mm shorter than A12. It has the shortest deck (the A12 is a full 10mm taller), so therefore the lightest weight
* No provision for positive crankcase ventilation
jpg  A10_blok [with bearings].jpg (81.34 KB)
174_691193d06cdaf.jpg 800X896 px
Posted on: 11/10 7:30
1.1 liter A10 engine
This A10 cylinder block sold last week on Yahoo for $120 USD. Seems like a superb bargain for an overbore to 76.85mm, resulting in 1.1 liter (1094cc which is 106 more than stock). However, it looks like there may be crack in the deck by the no. 1 cylinder, but it might be just a scratch
jpg  crack or scratch.jpg (171.78 KB)
174_691198748bc26.jpg 900X1200 px
jpg  A10 overbored to 76.85mm.jpg (147.89 KB)
174_691198843851f.jpg 900X1200 px
jpg  A10 front cam plate.jpg (175.87 KB)
174_691198966e9ee.jpg 900X928 px
jpg  A10 bottom end with 3 main bearings.jpg (161.27 KB)
174_691198b6db7fe.jpg 900X1200 px
jpg  A10 front suction pipe.jpg (150.36 KB)
174_691198c7369a0.jpg 900X1200 px
jpg  A10 left.jpg (168.50 KB)
174_691198cd9af80.jpg 900X1200 px
jpg  A10 block RF.jpg (138.40 KB)
174_691198d5cdcca.jpg 900X1200 px
jpg  A10 back.jpg (145.15 KB)
174_69119918e0e03.jpg 900X880 px
Posted on: 11/10 7:47
