Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Extracrors Wanted in Adelaide
CraigSalter
Posted on: 2003/2/26 14:59
Hi All, got a '84 vanette with A12 engine, keeps braking bolts on split manifold. Looking for a set of extractors to suit. Can any one help.
Craig
#2
Re: Extracrors Wanted in Adelaide
Posted on: 2003/2/26 17:18
Craig, extractors generally have more bolt problems than cast manifolds. If they are breaking, they are either the wrong bolts, or they are too tight. Use a torque wrench to tighten to spec -- it's only 0.9-1.4 mkgs on the manifolds -- not very tight.
#3
CraigSalter
Posted on: 2003/2/27 2:58
Thanx ddgonzal, for the info, one off the blokes I spoke to in a spare parts place suggested I try extactors, the main problem is, the bolts holding the inlet and exhaust mainfolds together either snap off or come loose. Thanx for the wrech settings as well.
Cheers Craig
#4
Sachman
Posted on: 2003/2/27 3:44
Have you tried requesting what you're after at http://www.apraa.com ?
#5
CraigSalter
Posted on: 2003/2/27 4:18
Thanx Sachman, I have now.
Craig
#6
1200rallycar
Posted on: 2003/2/27 12:22
ive got some extractors, 4 into 1
bottom end is 1.5" diameter $50 and they are yours im in melb, can send at your expense my bro goes over to adelaide often, are you in a hurry for them?
#7
CraigSalter
Posted on: 2003/2/27 12:27
Thanx 1200rallycar, let me see if I can get a set locally, if not, your on. I'll be in touch.
Craig
#8
1200rallycar
Posted on: 2003/2/27 12:31
no worries, ill ask my bro when he is going up next, if its soon they might be just the thing for ya
#9
CraigSalter
Posted on: 2003/2/27 12:33
Ok 1200rallycar. no real rush, but if no problem, I'm sure we can do a deal.
