Extracrors Wanted in Adelaide
From Adelaide, South Australia
Hi All, got a '84 vanette with A12 engine, keeps braking bolts on split manifold. Looking for a set of extractors to suit. Can any one help.
Craig
Posted on: 2003/2/26 14:59
Re: Extracrors Wanted in Adelaide
Craig, extractors generally have more bolt problems than cast manifolds. If they are breaking, they are either the wrong bolts, or they are too tight. Use a torque wrench to tighten to spec -- it's only 0.9-1.4 mkgs on the manifolds -- not very tight.
Posted on: 2003/2/26 17:18
Thanx ddgonzal, for the info, one off the blokes I spoke to in a spare parts place suggested I try extactors, the main problem is, the bolts holding the inlet and exhaust mainfolds together either snap off or come loose. Thanx for the wrech settings as well.
Cheers
Craig
Posted on: 2003/2/27 2:58
From Perth WA
Have you tried requesting what you're after at http://www.apraa.com ?
Posted on: 2003/2/27 3:44
Thanx Sachman, I have now.
Craig
Posted on: 2003/2/27 4:18
From Melbourne, Australia
ive got some extractors, 4 into 1
bottom end is 1.5" diameter
$50 and they are yours
im in melb, can send at your expense
my bro goes over to adelaide often, are you in a hurry for them?
Posted on: 2003/2/27 12:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanx 1200rallycar, let me see if I can get a set locally, if not, your on. I'll be in touch.
Craig
Posted on: 2003/2/27 12:27
no worries, ill ask my bro when he is going up next, if its soon they might be just the thing for ya
Posted on: 2003/2/27 12:31
1200 Coupe Rallycar
Ok 1200rallycar. no real rush, but if no problem, I'm sure we can do a deal.
Posted on: 2003/2/27 12:33
