(1) 2 3 »
engine question??
Not too shy to talk
From Sydney
Guys,
For those guys with weber carb set ups (side draught) what did you do for the breathing ports on the top of the tappet cover and the side of the block????
What is the best way to deal with this so that you dont suffocate the engine??
I know for the down draught webers you can plumb the ports back into the inlet manifold but with the set up in mine that cant be done to my side draught manifold.
help would be greatly appreciated
Posted on: 2003/3/9 10:01
Re: engine question??
The breather on the top of the rocker cover is for fresh air, so often those with Weber carbs simply plumb this to a small air filter ... that's what I did for my downdraft Weber.
The tap on the side of the engine is for PCV (Positive Crankcase Ventilation). If the sidedraft manifold doesn't have the tap for the standard threaded Datsun PCV valve, you could simply add a section of hose between the PCV valve and a regular (large) tap on the intake.
more info
PCV is good for oil control, a benefit to your street engine even if the main purpose is emissions control. At high vacuum, it keeps the crankcase under partial vacuum, so excessive oil isn't sucked past the rings. At low vacuum (full throttle) the pressure is likewise partially equalized.
In all cases a small metered amount of air is sucked through the breather into the intake manifold to whisk the blowby gases into the combustion chamber, keeping them out of the atmosphere and out of your lungs.
Posted on: 2003/3/9 19:16
Not too shy to talk
From Sydney
Thanks mate,
In that case then would it be ok if I made an oil catch can, mounted it to the firewall, ran a hose from the rocker cover to the top of this catch can and from the bottom of the catch can back to the PCV, that would do a good job as well wouldn't it ???
This is one of the things suggested to me by a friend who is into rallying.
Posted on: 2003/3/9 23:49
I don't think that would work. The rocker cover needs air, the PCV needs intake.
If the engine is ventilated correctly and the rings are in good condition, you don't need an "oil catch can" or oil-separator. I'm speaking of a street-going engine.
Posted on: 2003/3/10 0:51
From Warwick, QLD
What happens if you use a little air filter down on the cank case vent, but the filter has a few bent pipes on it to stop the oil coming ou. As thats what I've been told to do by many people
Cheers
Damo
Posted on: 2003/3/10 3:27
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
yes, just use a hose to a filter mounted off the engine. The bend in the hose will prevent oil from being thrown onto the filter.
Posted on: 2003/3/10 5:12
From Fort Worth, Texas, USA
It may have been a coincidence, but the one time I ran an A-14 with the the breathers set up that way, it started to smoke quite a bit. What I did on my last A-series with a side draft, was to plumb the PCV to the port for the vacuum assist brakes.
Posted on: 2003/3/10 18:04
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
That's what I've been trying to say ... the PCV should be connected to intake manifold vacuum.
Posted on: 2003/3/10 18:56
From Melbourne, Australia
two hoses straight to a fabric softner container with a scourer cable tied over the top works a treat for me
keeps the scrutineers happy too and the cops dunno what it is so dont question it much
Posted on: 2003/3/11 8:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, Australia
Does the fabric softener bottle have to be "Cuddly" ..hhehehehe
You seem to have a fetish for laundry goods. Do you prefer to use pantyhose to tie up the scourer?
Chris
Posted on: 2003/3/11 12:34
(1) 2 3 »
