Help!!! H190 diffs parts needed
From Edgewood, NM USA
I posted this to the News section (sorry) I think this is a better place for it.
I am desparately seeking parts to complete the setup of two H190 differentials for my 1200 GT5 race project. I need new pinion pre-load spacers (either the crushable ones or the solid spacers with shims) and pinion oil seals to fit the aluminum housing (slightly smaller that the seal for the steel housing). Does anyone know of a source in the US to purchase these from or does someone here happen to have a few new sets gathering dust they might be willing to sell? My local Nissan dealer parts guy just gives me a blank stare when I ask for them I'm also looking for spare 4.8:1 ring and pinion sets or complete rearends (pumpkin) for the H190. Classicdatsun.com is willing to take my diffs and have them setup for me for a price but all I really need are the parts to do it myself. Any help or suggestions will be greatly appreciated. Thanks.....Mike
'72 Datsun 1200 Coupe street car
'71 Datsun 1200 2 door sedan (autocross car?)
'70ish semi tube chassis datsun 1200 GT5
Posted on: 2003/5/30 18:04
Re: Help!!! H190 diffs parts needed
Hi Mike,
Sorry, Can't help with the crush washers, but I do have a complete 4.87 R&P in an aluminum housing (welded spiders) and also a NEW in box 4.87 R&P.
e-mail if these would be of help?
Thanks
Jeff@knoebel.com
(414)861-1614 cell phone
Posted on: 2003/5/31 5:14
From Stone Age somewhere in U.S.A.
you need to find a dealer who has some oldtimers
IF I remember correctly, the aluminum housings were used in the roadsters (SPL/SRL311), and yes they are different than the later ones.
the best that I can offer right now is this, after the weekend I'll go visit the dealer I used to work at and get you more info, but it's going to take a few days
Posted on: 2003/5/31 6:32
From Melbourne, Australia
Hey,
can anyone point me to some info on the GT5, what gear did it have in it that was diffrent to the usual 1200's?
Posted on: 2003/6/1 9:21
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Millgrove Vic OZ
Alloy carrier H190's were used in roadsters, J1500's, 520's, 620's, 411 bluebird SSS's, works rally car PA10's and the mighty FJ24 240 RS. I have probably missed a few as well.
Posted on: 2003/6/1 12:55
use this; [/url]www.gt-racecar.com
Posted on: 2003/6/2 0:29
What is GT5?
These are customized car for racing.
Posted on: 2003/6/2 2:07
GT5 is the smallest bore class of the SCCA GT cars. Generally you can change almost everything on the car (including building a complete tube chassis) except for engine type/size (1300cc max) and wheel/tire size. GT5 cars are restricted to 13x 6 wheels and an 8x20 inch tire (slicks are of course permitted). The skys the limit on engine modification (some restrictions are spelled on on the GCR spec line for each car model) with individual port fuel injection and one carb throat per cylinder permitted. Bodies can be mostly fiberglass and sometines can be upgraded to newer models (a datsun 1200 can be upgraded to a Datsun 350Z body) but the mechanicals stay the same. This is driven mostly by manufacturer contingency support for the marque. This call appeals to me as I like to build and try out home brew solutions to expensive race only parts. These cars are very fast and handle very well when properly set up. Rear wheel drive Minis are the current cars to beat in National class racing. Thanks for the input on what cars used the aluminun housing. Jeff I will contact you promptly about the diffs.
Mike
Posted on: 2003/6/2 15:20
oh cool thanks,
i was actually under the impression that the 1200 GT5 was a factory built "special edition" car (or something like that)
but apparently not
cheers guys
Posted on: 2003/6/2 15:30
1200 Coupe Rallycar
