#1 F/S BIG BORE 80 mm A14 forged pistons + block
bige Posted on: 2009/4/28 13:07
I have a set of new A14 80mm forged pistons cool coated (flat tops with valve reliefs) and race series rings/pins and block to suit.block has been offset sleeved & decked and blocked filled,still run water passages,also custom head gasket to suit. more info call ernie 0412 864 741 located sydney : (open to respectable offers')
jpg  new.JPG (73.91 KB)
9764_4be26edab647f.jpg 490X368 px
#2 Re: F/S BIG BORE 80 mm A14 forged pistons
steveo Posted on: 2009/4/28 13:40
how much you asking for them?
Could these be modified to handle a boosted application?
Got any pics?
#3 Re: F/S BIG BORE 80 mm A14 forged pistons
bige Posted on: 2009/4/28 13:52
piston crowns are 6.7mm thick u could machine a dish in them to suit your specs.call me
#4 Re: F/S BIG BORE 80 mm A14 forged pistons
D Posted on: 2009/4/29 0:12
steveo you wont with 80mm unless the block is heavily modified
with full c sleeves and grout cemented bottom end.
#5 Re: F/S BIG BORE 80 mm A14 forged pistons
letsrace Posted on: 2009/6/7 19:48
hi mi name is hector am intrest in dose piston how much
#6 Re: F/S BIG BORE 80 mm A14 forged pistons
bige Posted on: 2009/6/8 0:41
pm sent
#7 Re: F/S BIG BORE 80 mm A14 forged pistons
bige Posted on: 2010/5/5 13:52
its back any interests call me 0412 864 741 or pm (open for respectable offers) .cheers
#8 Re: F/S BIG BORE 80 mm A14 forged pistons + block
bige Posted on: 2010/5/9 12:25
bump
#9 Re: F/S BIG BORE 80 mm A14 forged pistons + block
estyre Posted on: 2010/5/9 12:32
hhmm what brand pistons and ,just to clear things up ,the the block has been cemented ?
ide be keen if this is for sale in a couple of weeks !
#10 Re: F/S BIG BORE 80 mm A14 forged pistons + block
bige Posted on: 2010/5/9 12:50
yes it is cemented[block fill was used]still with water passages. the pistons are venolia race series, cool coated, total seal rings. 2piece 2second ring custom made. cheers
