F/S BIG BORE 80 mm A14 forged pistons + block
From sydney.nsw
I have a set of new A14 80mm forged pistons cool coated (flat tops with valve reliefs) and race series rings/pins and block to suit.block has been offset sleeved & decked and blocked filled,still run water passages,also custom head gasket to suit. more info call ernie 0412 864 741 located sydney : (open to respectable offers')
jpg  new.JPG (73.91 KB)
9764_4be26edab647f.jpg 490X368 px
Posted on: 2009/4/28 13:07
Edited by bige on 2010/5/5 13:41:05
Edited by bige on 2010/5/5 13:53:58
Edited by bige on 2010/5/5 13:55:06
Edited by bige on 2010/5/6 8:25:34
Edited by bige on 2010/5/20 23:03:09
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: F/S BIG BORE 80 mm A14 forged pistons
From newcastle, NSW
how much you asking for them?
Could these be modified to handle a boosted application?
Got any pics?
Posted on: 2009/4/28 13:40
From sydney.nsw
piston crowns are 6.7mm thick u could machine a dish in them to suit your specs.call me
Posted on: 2009/4/28 13:52
steveo you wont with 80mm unless the block is heavily modified
with full c sleeves and grout cemented bottom end.
Posted on: 2009/4/29 0:12
From puerot rico
hi mi name is hector am intrest in dose piston how much
Posted on: 2009/6/7 19:48
From sydney.nsw
pm sent
Posted on: 2009/6/8 0:41
From sydney.nsw
its back any interests call me 0412 864 741 or pm (open for respectable offers) .cheers
Posted on: 2010/5/5 13:52
Edited by bige on 2010/5/20 23:04:37
Re: F/S BIG BORE 80 mm A14 forged pistons + block
From sydney.nsw
bump
Posted on: 2010/5/9 12:25
From mandurah
hhmm what brand pistons and ,just to clear things up ,the the block has been cemented ?
ide be keen if this is for sale in a couple of weeks !
Posted on: 2010/5/9 12:32
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
yes it is cemented[block fill was used]still with water passages. the pistons are venolia race series, cool coated, total seal rings. 2piece 2second ring custom made. cheers
Posted on: 2010/5/9 12:50
