Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Jim's everything must go sale
PurpleJim
Posted on: 2009/10/28 8:23
Hey all,
Moving yet again so finally time to let go of all my project/spare parts *** Can post photos tomorrow *** Cars: *180b SSS - stripped for paint, light coat of primer, rust around rear windscreen and rear wheel arch - no engine, offers? (also cheap) Turbo stuff *1 piece L-series carby turbo manifold - $300 *Stock L18 efi manifold with all injectors etc (no ecu, afm) - $350 *Stock CA18det T25 *3 x Lseries 5 speeds $100 ea (trx, S2 bluebird, unknown) *1 x fully reconditioned Lseries auto - anything over $10 and it's yours Make an offer stuff *a12, big cam, side draught webber, new bearings etc *4 speed *32/36 carbs ( *large su for suckthrough (will check size) *Stock L20 diesle turbo exhaust manifold - cracked *L18 engine dismantled but complete *L16 rods and pistons *L18 rods and pistons *L16 crank *Rebuilt Stanza calipers with new pads *Hydraulic clutch master cylinder - engine bay mounted(was to be used for CA18 conversion) *351 Cleveland engine and auto That's all I can think of, probably lots more. Everything is in Geelong, can post small stuff, time to get rid of everything before I wake up without my testicles.
#3
Re: Jim's everything must go sale
reuby_tuesday
Posted on: 2009/10/28 8:35
You buying me a present Dundee?
#5
Davooo
Posted on: 2009/10/28 8:55
keen on the a12 cam what are you looking for it ?????????????????????
#6
estyre
Posted on: 2009/10/28 9:24
how much for the calipers ?
and would they fit on 120y struts
#8
PurpleJim
Posted on: 2009/10/28 10:47
Edit on the Hydraulic clutch, is just a master cylinder that I was going to use in my CA conversion, sorry guys.
No idea what the cam is so will check and get back to you tomorrow night Davooo. Would rather the whole engine went though. As for the calipers, not sure if they will fit 120y struts, should be in the wiki or an old post, will check tomorrow when I get two free seconds. Cheers.
#9
PIGDOG
Posted on: 2009/10/28 10:53
got a decent L18 crank jim? might be needing one
so all the non 1200 stuff is going then?
#10
PurpleJim
Posted on: 2009/10/28 11:06
Yep Nick,
Have an L18 crank wrapped up and fish oiled. Will check the condition tomorrow for you. And yep, everything non-1200 is going, except my turbo-efi L18. You can view topic.
