Jim's everything must go sale
From Everywhere, mostly Melb/Geelong/Ballarat
Hey all,
Moving yet again so finally time to let go of all my project/spare parts
*** Can post photos tomorrow ***
Cars:
*200B sedan complete, rust hole in bootlid, engine out of car, all trim, etc still in car - good condition, offers? (cheap, want it gone)
*180b SSS - stripped for paint, light coat of primer, rust around rear windscreen and rear wheel arch - no engine, offers? (also cheap)
Turbo stuff
*1 piece L-series carby turbo manifold - $300
*Stock L18 efi manifold with all injectors etc (no ecu, afm) - $350
*Stock CA18det T25
*3 x Lseries 5 speeds $100 ea (trx, S2 bluebird, unknown)
*1 x fully reconditioned Lseries auto - anything over $10 and it's yours
Make an offer stuff
*a12, big cam, side draught webber, new bearings etc
*4 speed
*32/36 carbs (3, 2, dismantled but complete)
*large su for suckthrough (will check size)
*HKS blowthrough turbo hat for 32/36 weber Sold pending payment
*Stock L20 diesle turbo exhaust manifold - cracked
*L18 engine dismantled but complete
*L16 rods and pistons
*L18 rods and pistons
*L16 crank
*Rebuilt Stanza calipers with new pads
*Hydraulic clutch master cylinder - engine bay mounted(was to be used for CA18 conversion)
*351 Cleveland engine and auto
That's all I can think of, probably lots more.
Everything is in Geelong, can post small stuff, time to get rid of everything before I wake up without my testicles.
Posted on: 2009/10/28 8:23
Edited by PurpleJim on 2009/10/28 10:37:20
Edited by PurpleJim on 2009/10/29 9:35:11
Re: Jim's everything must go sale
From Freo
PM'd..
Posted on: 2009/10/28 8:25
A15 PSI Project Motor
'72 CB750k,
From Coondle, WA Australia
You buying me a present Dundee?
Posted on: 2009/10/28 8:35
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Sydney
PM'd
Posted on: 2009/10/28 8:45
Not too shy to talk
From SA
keen on the a12 cam what are you looking for it ?????????????????????
Posted on: 2009/10/28 8:55
From mandurah
how much for the calipers ?
and would they fit on 120y struts
Posted on: 2009/10/28 9:24
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney
PM'd also
Posted on: 2009/10/28 9:50
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Edit on the Hydraulic clutch, is just a master cylinder that I was going to use in my CA conversion, sorry guys.
No idea what the cam is so will check and get back to you tomorrow night Davooo. Would rather the whole engine went though.
As for the calipers, not sure if they will fit 120y struts, should be in the wiki or an old post, will check tomorrow when I get two free seconds.
Cheers.
Posted on: 2009/10/28 10:47
From Geelong, Vic
got a decent L18 crank jim? might be needing one
so all the non 1200 stuff is going then?
Posted on: 2009/10/28 10:53
Yep Nick,
Have an L18 crank wrapped up and fish oiled. Will check the condition tomorrow for you. And yep, everything non-1200 is going, except my turbo-efi L18.
Posted on: 2009/10/28 11:06
