CA18DET Mad "D" engine conversion kit :) $45 & other bits
Spent quite some time drilling and shaping these mounts with the grinder for smooth edges, not to mention pulling apart a ca20 engine bay just to get to the Pintara crossmember and paying $40 for it after an hour.
All you need is to sit your ca18det on your crossmember with these babies on and just spot weld through the holes and presto. Metal is about 4mm thick so even can be done with an Arc welder set at 60-70amps.
Will suit a 1200 better than 1000 as I ran out of room
in my lil 1000 there is less room than 1200s.
$45 + 5 posted anywhere in Oz.
steering wheel boss dress kit made from billet alloy
can change button logo to datsun or other.
$15 posted Oz wide
Posted on: 2012/2/2 13:01
Edited by D on 2012/2/2 15:28:14
Edited by D on 2012/2/2 15:28:53
Edited by D on 2012/2/2 15:29:55
Edited by D on 2012/2/2 15:31:29
Subject Poster Date
     CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/2 13:01
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/2 15:45
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits supafatto 2012/2/2 21:45
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/3 0:53
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits Booyar 2012/2/3 1:01
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits DatsAndy 2012/2/3 2:51
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/3 4:43
           Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits 1200rallycar 2012/2/3 5:59
             Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits ddgonzal 2012/2/3 6:53
               Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits 1200rallycar 2012/2/3 7:31
                 Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/3 8:39
                   Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits 1200rallycar 2012/2/3 8:59
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits DatsAndy 2012/2/3 8:18
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits DatsAndy 2012/2/3 10:41
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/3 10:58
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/16 12:47
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/3 11:01
       Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits DatsAndy 2012/2/16 21:34
         Re: CA18DET Mad "D" engine conversion kit :) $45 & other bits D 2012/2/16 23:49
